comparison
Started by David_c, October 02, 2003, 07:03:46 PM
David_c
i was looking for a comparison between the stihl 460 and husky 385 any thoughts.
Gus
David,
I don't know enough about these newer saws to help you much. Be interesting to see what someone comes up with.
Gus
"How do I know what I think unless I have seen what I say?"
SawInIt CA
I have used both and bought a 460. With that said it had more to do with the dealer. I also like the "feel" of the 460. You can go the thier websites and get the stats on both.
Adamj
I don't have much experience with Husky. But, I believe the main difference is that the Husky is orange while the Stihl is orange and white.  I hope this helps.   ;D
David_c
i am new to stihl & huskys allways used junk. bought a 372 great saw but i wanted to try a stihl. was going to buy a used 066 for $400 but when i was at the dealers today i was checking out the 460 felt great in my hand and for a few hundred more and new what the hey. well i just wanted to see what you guys like better the 460 or 385. when i get the saw i'll let you know what i think of it.
Rob
Hey David,
       Personally I like my 385XP better compared to the MS 460,one of the main reasons is because I think Husky has a much better anti vibe setup they just seem smoother than the Stihls..The air injection is a nice thing also.Dont get me wrong both are good saws I just think the 385 is a better one thats all..I'm sure Russ will contribute to this thread cause I know he owns both of these saws..I hope this helps a little bit
                                           Rob.
SasquatchMan
Having just purchased a new Stihl (though not a huge one), I've just held a bunch of Stihls and Huskies, and read an awful lot about both, here and at other forums, and their sites.
Once you get past the guys who think that Huskies will "burn out" (because their dummy friend ran it lean or something) or the guys who think Stihls won't work in the rain (because their dummy friend's didn't), it seems to break down like this - Stihls idle terribly but work beautifully revved up, where huskies have a much smoother power band.  The huskies I've picked up felt "cheap" and the Stihls didn't, and I suspect this is due to the Husky using a spring-based Anti-vibe system and Stihl using rubber mounts.  I've been told that the Husky system is actually better in terms of anti-vibe, but I don't know myself.  Both now offer compensating carbs, winter setups, hi-tech filtration...
The only thing that seems to be "funny" on the new Stihls is that the oilers don't seem to crank a hell of a lot of oil out - I've been in touch with Stihl about this and haven't heard back yet.  Maybe the big Stihls are better for this, but some of the recent posts here indicate that a few people think the Stihls are putting out just barely enough...
Senior Member?  That's funny.
David_c
sasquatchman from what i gather is stihl oilmatic chain lubrication system doesnt need as much oil becuase it is going were needed not every where else. i have also done alot of research on both models and it seems you ask a hundred guys you get about as many differnt answers. but i do like to hear others opinions. i have the husky i do like it but i need to try a stihl just so i know for myself but i still want to hear what you guys think. Thanks keep the responses coming.
Mark M
I have a MS460 and it's a cuttin SOB. Throws so much sawdust I have to use my face shield. I have a little 345 Husky and a MS260Pro. The 260 is a little bigger but for some reason I usually use the Husky. I think it runs smoother but this is just my opinion.
David_c
jokers
Hi David
As Rob noted, I have both an ms460 and 385. You are correct that asking 100 different people will yield 100 different opinions. In that vein, here`s mine.
Both saws are powerful and cut fast. The 385 is slightly faster, especially with a longer bar. The 385 is also slightly smoother running due to the springs and there is no comparison between the Husky`s Air Injection and Stihl`s filtration, the 385 wins hands down.
The 460 feels more like a quality product when you are just handling it, but it is only a matter of perception which disappears when you run the saws. The 460 also weighs about a pound less than the 385, which is noticeable and I like the Elasto Start better than simply having decompression on the 385.
The Huskies still have a lifetime warranty on the ignition and Stihl no longer does.
Oilomatic is another pipedream, new Stihl oilers are anemic.
One advantage the Stihl has however is that you can order a dual port muffler cover for an 044 that will give you about an extra 1/2 hp, you would have to modify the stock Husky muffler.
Ultimately the choice is your`s David and it looks like you already picked the Stihl, why ask now?
Russ
David_c
well russ thanks for your imput and why ask now good question just thought i would no one ever accussed me of be smart. ;D
jokers
Hi David
I guess after rereading my reply, my question of "why ask now?" could be taken as deragatory. It wasn`t meant that way and I`m glad that you didn`t take it that way.
Since you are buying an ms460, I think you will be happy with it compared to the 385. Both are good saws with specific small strengths and weaknesses.
I would not however recommend that anyone buy an early 046 with the metallic flywheel. I know first hand that they were slow revving and had a propensity for snapping cranks when the chain brake was applied at high rpm, as in a kickback situation. Stihl seems to have solved that problem by intalling a composite flywheel and somewhere along the way they also boosted hp from 5.7 to 6, maybe also related to the flywheel.
Russ
Typhoon
I have ran both stihls and huskies. Both are obviously top quality and high performance saws. So in my opinion you cannot go wrong with either. But in my personal experience, the only differences I find is that the huskies have a smoother feel, rev just a little faster, and idle better. The difference is not vast, but there is a difference. And im a big fan of the air injection. I think its an engineering marvel.
Hope this helps. Just an opinion.
-Brad
Brad Dawson, Anna IL (Southern tip)
Husky 346xpNE, Husky 357XP, Norwood Lumbermate2000
David_c
thanks guys: Russ dont worry i say things all the time people misinterpet. this is more of an experiment i have never had either till i decided on husky when i was buying new saws but i have to try a stihl just to satisfy my own curiousity although an expensive one. i also like to hear what others have to say not that i allways listen ;D anyway thanks for your thoughts and keep them coming.
Gus
David,
 I'm a Stihl guy. Never owned anything else with the exception of a spare saw I had for a long time. It was a jonsered 630. I have run husky's though; grabbing one from time to time on the landing to make a quick cut when my stihl was on the skidder. What these guys say about the husky being a smooth running saw is no joke. Every time I pick one up that is the formost thing I notice; smooth acceleration.
Gus
David_c
thanks Gus i really like my husky 372 great saw but like i have said i have never had a stihl and i wanted to try one before i decide i only want huskys. Gus why do you like the stihl saws?
SasquatchMan
The Husky/Stihl debate reminds me of the Chevy/Ford debate amongst farmers around here.  Difference being that Toyota has always made better trucks than either Chev or Ford!
I'm new to the debate, and bought a Stihl partly because I was told that the particular dealer I bought from was reliable, and the things were on sale to boot, and partly because the choke control on the Husky/Jred saws looked to be a bit small for using at -20.  I might well have bought something else if there was a different dealer near me.
As a carpenter, I've noticed that guys who use the red brand do so because they just always have, and are used to the red brand, and guys who use the blue brand are the same.  And a few guys will have all sorts of different brands of tools, having bought the "best" (for whatever reason) of any particular brand, knowing that they're all pretty good.
That said, my truck is a Chevy, cause Fords suck.   :D
David_c
hey sas about the ford chey thing my dad allways loved ford me chevys but i had an 99 ford ranger awsom truck just got to small for the family now i have 01 F150 not happy but better than chevy but if i get a small truck again it will probably be a yota they do last.when it come to tools i do like to own the best in my mind anyway ;D thats why i try differant brands.
SasquatchMan
Well, hey, a chainsaw is more important than a truck anyway, right?  :D
I've got a chev with 240000km on it, and it's still a strong truck, but I never woulda bought it if Honda or Toyota or Nissan made a big truck.  As for Stihl, well, I've got one and I like it, but it won't take much of a conundrum to give me reason to buy a 272xp as well!  Hope my wife doesn't see this.   :-X
David_c
yeh i hear you there mine dont know about the 460 wont till its to late :D. i have 60000 miles on my F150 since first week have had vibration that wont go away cant seem to fix other than that its been ok just drives me nuts ::). its a lease and i have put so many miles on it cost to much to return so i'll have to keep :( but what can i do grin and bear it. oh yea one other thing that just came about the hood wont open. that was fun when i went to have oil changed the other day :D
AndyB
The solution, whether it's a chainsaw or a truck regardless of manufacturer, is to not buy one that was manufactured on Friday or Monday. Thinking about what you are going to do on the weekend and recovering from the weekend is detrimental to quality control in manufacturing.  :D :D :D  I love my husky. ;D
SasquatchMan
They must not have weekends in Sweden, cause you never hear about a "lemon" Husqvarna, do you? ;)
Gus
David,
 There are 3 main reasons I continue to buy stihl saws.
1: Reliability, I've never had a stihl that needed work other than adjusting the carb. Unless ofcourse I dropped a tree on it ::)
2: Dependable service from stihl. Where I get my chains, bars and saws; all they do is work on stihls, nothing else. They know their equipment.
3; I like the way they feel. Probably just a habit. But with something as dangerous as a saw can be, I believe this to be important.
If I was to get a rabbi good deal I couldn't refuse, I'd probably buy a Husky. Got nothing against them.
Guess buying a stihl has become a habit with me ;D
Gus
David_c
Thanks Gus good as reason as any. i figured i need to try out both just to see which i like better.
