Building A Gang Saw
Started by Kevin_H., December 15, 2003, 03:41:10 PM
Kevin_H.
I'm Thinking about trying to build a gangsaw, It would only need to pass a 1 1/2" x 8" x 36" board. It will be producing 1 1/2" x 1 1/2" square pcs.
has any one attempted this?
I am figureing 6 blades, I have an idea about how to build the arbor, but dont know how I will do the feed system, or how much HP may be needed to run the 6 blades
Still in the doodling stages
Any idea's? Throw'em my way.
Got my WM lt40g24, Setworks and debarker in oct. '97, been sawing part time ever since, Moving logs with a bobcat.
EZ
All I can say is that I went to a auction last summer and they had a gang saw with 4 blades and it had a 20 hp electric on it. Did'nt see it saw. Good luck with your project.
EZ
Don P
5 horses per blade is a rule of thumb. We had a thread not too long ago, I think SawyerKirk was building one?
Our gangsaw has arbors just long enough to handle 5 blades at a 6/4 spacing. top and bottom 13 inch saws. Each arbor has a 75 horsepower motor. You can cut up to 4 inches with just the bottom or a max of 8 using both. there is another 25 H.P. motor that handles the drive.
Even at 75 horsepower, cutting 6/4 by 3.5 out of white oak or hard maple is ALL that saw wants, of course were honking it through there. We cut a lot of inch and a half square stuff with it for stake material.
sawyerkirk
I gave up!! you can get by with 2hp per blade, but more is better. Sawmill exchange has some! but if you are determined, you can take a small gear drive motor with a tire mounted on it to use to move your lumber through it.
Kevin_H.
Looks like maybe we are going to convert an edger, That should take care of the feed problem Still just kicking it around,
one problem is we dont have a good machine shop around here to make some of the needed parts.
