Amazing trailer riser bunks!
Started by hackberry jake, October 08, 2015, 10:05:32 AM
hackberry jake
Are you constantly banging up your trailer fenders with logs or tractor forks? Well say no more! I have the solution for you! The amazing trailer riser bunks! Raises the working height of your trailer about 1" above the fenders making clearance for forks and with the side stops, the logs can't roll into the fenders anymore. Order today while supplies last!
Percy
If I pay for shipping, do I get an extra set for free.....like if I order right now???? Next 60 seconds?? :D
Sixacresand
Looks good.  I can imagine the inventory is what we see in the Photo.  :D
red
rasman57
Just in time too.  Sure don't want anything dinging up those fenders.   Great idea.
How many loads of logs have you hauled with those riser bunks? just curious....
smoker62
hackberry jake
Quote from: rasman57 on October 08, 2015, 12:00:16 PM
:D
Quote from: beenthere on October 08, 2015, 01:01:27 PM
Year to date? Mumble mumble_carry the one _mumble mumble... Zero. Are you saying they may not hold up?
sandsawmill14
 if they dont hold up you can use what i do 2  7x9 rr ties with a 4x6 on top of them for clearance for the forks ( my forks are 3" thick) you may only need a 2x6 instead of 4x6 :)
ladylake
 I'd almost bet they wouldn't hold up to real life abuse, railroad ties would.  Steve
red
Not hold up?   They are held together with Gorilla Glue
drobertson
they will work, but some blocking would sure be easier,, unloaded too many to  count from those utility trailors.  Fenders just stink but it's all many folks have,
Delawhere Jack
Can I pay for them in E-Z monthly payments?
21incher
I'll take mine in JD green. Looks like it is to late to save those fenders. :)
Glenn1
Vacutherm IDry, Nyle 53 Kiln, New Holland Skid Steer, Kaufman Gooseneck Trailer, Whitney 32A Planer
Larch
I owned a non deckover trailer once.  ONCE!!!
Jemclimber
My fenders don't look as nice as yours. They've been reshaped many more times. :D
lt15
fishfighter
As rough as my tree guy is, I would give those bunks about one load before they collapse. And yes, he banged up a fender the other day. :D
WV Sawmiller
Jake,
   You have restored my faith in the common man!
   I look at all these fancy sanded, stained, polished and varnished wood projects with tight fitting dove-tailed and tenoned joints with precise measurements made by these super duper wood workers who post on this site and it is refreshing to finally see someone actually post who has carpentry skills on par with my own.
   Keep up the good work (Oh- and keep your hands and feet out from under that contraption when in use).
The term "Redneck" keeps coming to my mind, and that is a high compliment.   smiley_thumbsup
hackberry jake
They worked great! I did break one of the end stops when I let a log go too violently, but I will re-engineer that feature.
deadfall
Still, a squint in the crystal ball and I see beefier ones when you build your next set.
W-M LT40HD -- Siding Attachment -- Lathe-Mizer -- Ancient PTO Buzz Saw
Happy for no reason.
sandsawmill14
jake just becareful braking and going up/down hill is where trouble is most likely to happen. if they happened break over the chains and the logs would be loose. could be very bad :o
Larry
I used to haul grade walnut to a big mill to sell wholesale once a week.  The mill had a forklift with 8' forks and they liked to pick up a load in one nice swoop to take it directly to the grader.  Hands never touched the lumber in this operation.
I had to adapt my trailer in a similar manner.
That old saying, poor people have poor.....
