Sawing spruce again
Started by ladylake, May 23, 2014, 05:33:40 PM
ladylake
Sawing spruce yesterday again, a brand new 7/8  10° blade was up and down some but not terrible in not real wide spruce around 12", then I put on a 4°  3/4 tooth  resharpened blade with way better results,
way better but still not quite perfect as when pushing to hard in the wider cuts I'd still get a wave but not very often and I cut about 10 logs with the same blade... Those 3/4 pitch blades do work better in spruce.   Steve
red oaks lumber
spruce, there's a oops from mother nature :)
Peter Drouin
Spruce is easy if green, But dry is a pith  :D
A&P saw Mill LLC.
License NH softwood grader.
Bruno of NH
I too was cutting spruce today .
Full of knots was like milling steel .logs have been cut for 3 years .
I'm new to milling my next logs are hemlock I hope they mill better .
Jim Bruno of NH
petefrom bearswamp
Jim, you will find Hemlock a lot friendlier than Spruce.
Blades will wander over the knots, but not make the wavy boards that seem to come from Spruce.
pete
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
Peter Drouin
If the blades are sharp they cut flat. Pete try the 1 1/4 55 7°
A&P saw Mill LLC.
Hemlock cuts mighty nice on a Thomas. I just use the 10° blades. Not saying that is what to use,just saying that is what I use.
Those hemlock will peel mighty easy this time of year too. I run the saw just through the bark the whole lenght of the log. Than I use a tire wrench to work under the bark. I need something better,wider,but it works mighty nice and quick too.
nk14zp
Make a spud from a piece of old leaf spring.
Belsaw 36/18 duplex mill.
Belsaw 802 edger.
http://belsawsawmills.freeforums.org/
It's on my list. If I was doing more of it,I would make one. I think my Father loaned his out to one of my brothers,about 30 years ago. Who knows where it is now.
47sawdust
I've been peeling fresh pine logs this week.I use a spud I made out of a leaf spring with a slight curve.I sharpened it on 3 sides and  welded it to a 20'' piece of pipe.Man the peeling goes pretty good this time of year.A debarked log can be pretty slippery,not always a good thing.
Mick
That bark,shiney side up will find you in a heap on the ground mighty quick too.  ;)
Ray, when I want to peel any log I grab an old roofers tool designed to replace roof shingles. Don't know the proper name but its long with an offset handle and slight curve designed to go under a shingle and hook and pull the nail. I use it upside down and it follows the curve of the log, best bark stripper I've ever used. Frank C.
I know what you mean,never used one,but have seen them. I need to get some more stuff done around here. The "stuff"never really gets "done".  :D  I need to get up in the woods and get some hemlock out. I might built the wife a small sugar shack. I might even built a spud. I have all the stuff kicking around here. Just have to fo it.
petefrom bearswamp
Peter, I have used the .055 7 degree blades better but still not great.
This was in plantation grown Norway.
Kubota 900 RTV
Brucer
Several years back I was asked to resaw some 22" dry Spruce cants. You could surf on the waves. My only blade back then was the 1-1/4, .045, 10°, 7/8 pitch. Nothing I did could solve the problem -- brand new blades, realigned the mill, flooded the blade with lube, sawing at a crawl. The customer was not happy, but he could see I was doing everything possible to get a decent cut.
I spoke to WM about it and they suggested I try the new 7° blades, in 1-1/2" width. Same thickness, same pitch. Those made all the difference.
I've never been asked to saw Spruce again, but it's nice to know about the 3/4" pitch. Never know when someone is going to drop by with something unusual.
Bruce    LT40HDG28 bandsaw
roger 4400
Hi. I also use a 1 1/4  3/4  10 degrees on a Baker mill, I go slow and have no wavy boards with spruce. Last year I had 2 big spruces 24 in. from which I had 25  full 2X12 17 ft long without problems. Good luck.
Baker 18hd sawmill, massey Ferguson 1643, Farmi winch, mini forwarder, Honda foreman 400, f-250, many wood working tools, 200 acres wooden lots,6 kids and a lovely and a comprehensive wife...and now a Metavic 1150 m14 log loader so my tractor is a forwarder now
