cutting a banana
Started by curved-wood, March 18, 2018, 08:48:38 AM
curved-wood
Frame is cut from a curved branch of a large white pine. A real banana...yes a white pine that grows bananas...sorry no seeds available. The exterior shell  is in russian exterior grade plywood , 1/8 '', 3 plys, pick-up in the garbage. At least I got some good garbage from the russians ! The small shelter that I call a banana boat, is use to put firewood in. I am able to move it around with the forks of the backhoe. I could even go in the forest with it and pile my wood right there and bring it beside the house in the autumn. Minimum handling...with age I have to try to use my intelligence because I am getting lazy !
Brad_bb
Well isn't that something?!
WV Sawmiller
  That's cool. :o Very creative and great use of natural features in the wood.
DbltreeBelgians
Now that's using the ol' noggin. Ya done good on that. Pretty cool. smiley_thumbsup
samandothers
Looks like you have the bow just need the rest of the boat.
Very creative!
Crossroads
Joed
Valley Big Green Monster
newoodguy78
Well done that is impressive!! The siding looks awesome too  8)
Savannahdan
I need one of those to aggravate my neighbors who don't have an appreciation for awesomeness.
Husqvarna 3120XP, Makita DCS7901 Chainsaw, 30" & 56" Granberg Chain Saw Mill, Logosol M8 Farmers Mill
Already had me out in my yard trying to find a curved tree to kill.
curved-wood
Needs to be very crooked otherwise it is difficult to use. On other structures I have to laminate thin layers.    So now lets put a  new norm in log : very straight or very crooked !    ;D
The curve has to be in only one direction i.e. not twisted. If it is twisted the log have to turn at the same time it is saw. My son and I  did make a didgeridoo, that is a kind of australian instrument of music that you blow in. We use a branch of staghorn sumac, that is a soft wood with green and yellow strips with a corky heart . So we cut it in half by turning the branch as we were sawing.  A guide was used  to retain the branch from flying around.  After empting the hart, the 2 halfs were glueded back together.  The result was an amazing form. Isn't wonderful all those curves that you could produce with a band saw !!
Darrel
I've got some curved trees in my yard!
Do you think it's crooked enough?
1992 LT40HD
I wouldn't cut those. That's one steep side hill.
Or maybe you could just click the rotate image button.
Kbeitz
Growing on a hill like that it's going to have some real stress in it. That will be one that jumps off the mill while you'r cutting it.
Love machine shop work
and Wood work shop work
And now a saw mill work
Darrel
 :'( Bad me. I didn't hold my phone right. I could rotate it but I have no idea which way to rotate it because it is right on my iOS device. If I were to fix it it would be wrong for everybody with an iPhone or iPad. Sorry.
1992 LT40HD
Rotate it until it's straight. It ain't banana science.
Downstream
Now that is one of the coolest ideas I have seen awhile.   :)
EZ Boardwalk Jr,  Split Second Kinetic logsplitter, Granberg Alaskan Chainsaw Mill, Stihl 660 and 211, Logrite 60" cant hook, Dixie 32 Tongs
Percy
Quote from: Darrel on March 18, 2018, 08:18:34 PM
Oh ya!! That's more cooked then my lawyer....😁
LeeB
Looks like you've done this more than once.
starmac
What is the plans for it, inboard or outboard?
Would make an interesting shelter for the kids school bus shelter.
curved-wood
To Darrel : the roof ridge of that building could use your banana
Lumbergent
Great work Curved wood
You wouldn't happen to have some litterature on this ''wood'' you?? :P
Futur Hobbit
