needed help
Started by trapper, November 01, 2018, 11:34:05 PM
trapper
Cutting trailor decking for local mechanic 28in x 14ft oak was too much for the
harbor freight winch on my lt30 manual to load.  Also brought a small skidloader to handle the 2x12x14 boards.  Gave him a big discount for the help.
terrifictimbersllc
Looks like you got it under control.
28 x 14' oak would be almost at the weight limit on my hydraulic mill.
samandothers
Where there is a will there is a way!
Resonator
Good thing he was paying you, and not the other way around. "Some places charge an arm and a leg for a big tow." - old saying
