Building a mill.. FIRST LOG WAS A SUCCESS!!
Started by jwh f-100, January 12, 2018, 01:31:50 PM
Hilltop366
I had a worm gear winch on my DIY mill, it works but slow, I also had a brake on the saw frame to make sure it did not creep while sawing.
I can't remember the pull rating on mine but the larger the capacity the slower it will go. I guess that is why you often see a lift assist on factory made manual mills, a lift gas shock or garage door spring sort of setup then you can have a high ratio lift mechanism that is fast and requires little effort to move and hold in place.
If I was making a stationary mill and weight did not matter I would be tempted to use a counter weight.
jwh f-100
Quote from: Hilltop366 on January 15, 2018, 04:00:03 PM
I like the idea of a clamp and a torsion rod. I have my feelers out for some garage door parts..
I'm also thinking about some type of secondary tensioner/handle on the cable. It will tighten the cable just enough for the blade to clear the log while backing up, but leaving the winch in its original location.
Why buy it when you can build it.
Kwill
Quote from: Crusarius on January 15, 2018, 02:12:26 PM
I ended up with acme threaded rod for raise and lower. Some ways I wish I had gone simple with a winch but have to much invested not to change.
what kind of acme did you use? I see surplus center has what they are calling lead acme thread. I would think it would be soft and wear out quickly
Built my own log arch
built my own bandsaw sawmill
Built my own atv log arch.
Built my own FEL grapple
Crusarius
Whatever linn lumber sent me. The threaded block is brass so the rods should last just fine. its 1". 5 turns per inch of travel.
The blocks are just solid so I think I am going to drill and tap them for grease fittings.
I wouldn't. I'd lubricate with a fine lubricant.  Grease, fine sawdust, threads, BAD!
Ljohnsaw
Quote from: Kwill on January 15, 2018, 07:15:38 PM
It depends on how you pronounce it!  I think they meant leed as opposed to led.  i agree, lead (led) would be pretty soft! :D
ktm250rider
I just tacked up a HF worm gear winch to my mill in process.  Yes it is slow to go from the bottom to the top.  For making 1 inch adjustments it doesn't seem too bad.  Works great if you remove the handle and use a cordless drill.
Kbeitz
Quote from: ktm250rider on January 16, 2018, 07:45:23 AM
Better yet if you attach a wheelchair motor to it.
Love machine shop work
and Wood work shop work
And now a saw mill work
ktm250rider
Quote from: Kbeitz on January 16, 2018, 09:48:31 AM
Ugh, yup thats the plan.  Wouldnt you know I get a townwide email that a local resident is giving away (AKA FREE) a powered wheel chair.  Naturally i was number 2 in line and number 1 took it!
Kbeitz
Quote from: ktm250rider on January 16, 2018, 11:34:00 AM
Check the junkyards.
jwh f-100
Good idea with the drill. I plan to put a small steering wheel on mine..
Here is a basic drawing of my saw head..
FloridaMike
Or use a 12 VDC tarp motor.  I'm using one of these: LINK
Hope it was ok to post a non-sponsor link!
Mike
Mike
Crusarius
I would be real interested to know how that works I am using a wheelchair motor.
jwh f-100
Quote from: Crusarius on January 17, 2018, 09:39:42 AM
Have you guys considered a power window motor from a car?
Ljohnsaw
Quote from: jwh f-100 on January 18, 2018, 02:49:34 PM
I wouldn't think it would hold up.  Don't think they are made for the duty cycle (unless you have a 5-year-old...) or the power that would be required.
Crusarius
yes. I did. But I agree with ljohnson. I don't think they would hold up and also don't think they would have the power needed to lift my carriage. If I had one readily available I would be very happy to test it. But I really don't want to go pull one out of anything.
jwh f-100
Hey all.
The current debate between the right and left side of my brain is my clutch.
I am leaning  towards a manual clutch for a few reasons. Price, dependability, and size (speed) options..
Any substantial reasons not to use a manual clutch set up??
I have a mill that I just press the throttle and go,just like a chainsaw. I would not want to reach and push a lever to engage the motor. I looked at sawmills for 20 years before I bought the one I did. I have a shoulder that kinda bothers at time. No way could I do it. Even what little sawing I do.
Kbeitz
A good two belt centrifugal is not cheap ether.
BigZ La
I don't know anything about building a mill so I'm just throwing this out there, could a drive from a golf cart be used to drive a mill? As the engine speed increases the blade speed would increase. I don't know if they are designed for the amount of torque needed, I was just having a brain drain.  :D
jwh f-100
I will be using Cooks adjustable blade guides.
My cut width will be in the 26" to 28" range..
The "fixed" roller guide will be on the drive wheel side as it should..
My question is how crucial is it to have the other roller guide on a slide?? When in the 26"-28" range can they both be fixed??
Kbeitz
Crusarius
Linn Lumber sells a 2 groove clutch for $310.
jwh f-100
Quote from: Kbeitz on January 24, 2018, 08:12:29 AM
Mine is fixed. Works great so far...
Thanks.. What is your cut width??
The idea of, more or less, fixing it and forgetting it really appeals to me..   I can just imagine having everything tuned in nicely at 24", then narrowing the cut and messing up the adjustment..  In my eyes more components equal more opportunities for inconsistencies..
Crusarius
I have thought about that to but I like the idea of the extra blade being covered when your cutting.
