TJ 240E hydraulic oil
Started by 62oliver, August 11, 2015, 08:12:40 PM
62oliver
Husqvarna 266, Case 90xt, JD310C, TJ240E, 02 Duramax
deastman
It will do fine, tractor hydraulic fluid is usually a 20 weight oil. In winter you could use a AW 32 which is a 10 weight and is probably less expensive.
Samsung 130 LCM-3 with Fabtek 4-roller and Cat 554 forwarder, Cat EL 180 excavator, Cat D3C dozer, Cat D7E dozer, '92 Ford LTL 9000 dump, Easy-2-Load 25 Ton tag-a-long, current project under construction: '91 Peterbilt 379 with a Hood 8000 w/extenda-boom loader
