Pettibone MT5AD
Started by Wes Lyon, June 15, 2011, 12:15:11 PM
Wes Lyon
Hello everyone ..
Anyone have any specifics or experience on this old skidder model. I believe they were called Master 5's.  Looking for weight and what they had originally for a winch configuration and how they worked pulling little stuff?
Many thanks
Wes
logman81
Just happen to come across on for sale on Mass Craigslist it is a master six according to the owner. ;D
Precision Firewood & Logging
jocco
They were a decent old machine the ad may be a diesel some were gas. Gearmatic #9 winch was common. Not to common today and not worth too much. You can get some parts from pettibone some from logging supply outfits. Just guessing but weight under 5 tons. Contact me if you need additional help.
You may check out but you will never leave
logman81
Thanks for the info I think the master #6 on craigslist is diesel but not to sure. What they use for engines? What do you think it is worth in good working order?
jocco
Some use detroit 353/453, The master 5 i have seen with gas motor and JD diesel. They are obsolete and not a mainstream brand (like deere) So as to value They seem to be trading on the low side like $5-7000 You can still get some parts from pettibone. Might be a little harder to sell if that was your plan after job was done. They were morepopular in some areas of the country than others.
