Old chainsaw bars
Started by michiganmilkman, January 05, 2016, 02:28:57 PM
michiganmilkman
Hi does anyone know of a place to buy a  sawbar that can be modified to fit old saws. Kinda like a blank bar
Jhenderson
Their kinda spendy but I'm sure Cannon can help you out. Might even make it to your specs.
gspren
    Did you check with chainsawr, one of our sponsors? Maybe you could find a longer bar and shorten to make a blank, make a 20" out of a 24".
Al_Smith
The easiest thing to do is use a Stihl mount bar with spacers .For one the Stihl bars have a wide heel and above all else are readily available .
You might need to modify the bar tightening hole and oil hole but most of the time it's not that big of a deal .
If you care go to "chainsaw collectors corner " website .Look up Homelite 2100 S .That is my saw and it has a 36" bar made for a Stihl  066 .Windsor brand, Stihl mount .
michiganmilkman
Thanks that is exactly what I want to do. I have a old sears 917.61406. Its gear drive with half inch chain. Just want to keep the old thing alive and useful
Al_Smith
I've got one myself .Forget the Stihl bar then that be the case .
You will need a wide hard nose bar .
kantuckid
The Oregon catalog has pics/profiles with specs for their current blades- probably too narrow?
Kbeitz
What your lookin for.... Does it look something like this ?
Love machine shop work
and Wood work shop work
And now a saw mill work
Al_Smith
Close maybe however that appears to be Mall "planer chain " and likely isn't 1/2" .
If I ever get off work while the sun is still shining I'll find the bar and chain for that Sears gear drive that resides in my shed and attempt to post a picture of it .
Kbeitz
Yes it is a very odd ball chain.
