Husky with cracked gas tank
Started by TessiersFarm, February 01, 2013, 07:32:50 PM
TessiersFarm
I have a husky 394xp saw with a crack in the bottom gas tank seam.  Any suggestions for epoxy or a fix befor I have to order a new tank?
Stihl E14, 180, 026, 036, 361, 045
Husky 266, 372, 394
Dolmar 111
torqueporting
I drain saw tanks, let air dry, then use pvc pipe cleaner on the outside. Once clean, I take a wooding burning iron and gouge the entire length of the crack to create a V. I then push the high side of the V into the trough. Sometimes I melt a piece plastic into the V as I push the sides in. My extra plastic source is a damaged 272 starter. The thin bars are easy to cut out and control the rate of feed into the heat source.
Timbercruiser
You can buy good epoxy too for fixing cracked gas tanks. Clean it good with acetone and grind it out good. JB weld is a common one but one of many. Some Huskys seem to crack easy mabe just age
TessiersFarm
I cleaned it, sanded it, cleaned again and put the JB weld to it.  Will see tomorrow if it worked.  It is right on the bottom where it gets a beating, was thinking of sticking a piece of rubber on it to help protect it when setting it down.  I was thinking like the weather strip stuff.
Husky 266, 372, 394
Dolmar 111
