Need INFO
Started by POSTON WIDEHEAD, February 05, 2013, 10:26:08 PM
POSTON WIDEHEAD
My Husq. is a 365 special.
If you are behind the saw like you are sawing and your left hand is on the handle....just to the right of your left hand,  between the handle and the top of the engine is a spring.
My spring broke today.
I can see how it unscrews from the handle but how does it come off the engine? Thanks.
hamish
Remove the 4mm allen head screw that attaches the av sping to the handle, then re-insert the 4mm allen back into the smae hole and unscrew the rest from the cylinder.
Norwood ML26, Jonsered 2152, Husqvarna 353, 346,555,372,576
POSTON WIDEHEAD
