OWB Backup generator size
Started by Logging logginglogging, November 19, 2012, 02:17:07 PM
what size generators are u guys using to power the stoves when the lights go out? My father has a large one now that runs the stove fine  but we tried a smaller one once and the draw was too great and it stalled the generator.
NWP
I have a 3500 watt. It doesn't take much.  All it is running is the circulator pump and the blower motor.  The problem is that I don't have a way to run my air handler units.  So the stove is ok and circulates water, but I can't blow the heat off the exchangers.  We very rarely lose power so it doesn't worry me much.
1999 Blockbuster 2222, 1997 Duratech HD10, 2021 Kubota SVL97-2, 2011 Case SV250, 2000 Case 1845C, 2004 Case 621D, John Deere 540A, 2011 Freightliner with Prentice 120C, 2012 Chevrolet, 1997 GMC bucket truck, several trailers, and Stihl saws.
mojamboo
I have a 7000 watt, 8000 surge Costco (champion) generator tied into a gen-tran panel for the house.
We wanted to live while the power is out, so we had to consider furnace, circulators, well pump, and then 90% of the house.
Love it...as I am on a dead end dirt road, off a dead end dirt road, off a dirt road, we aren't top of the power companies list during outages.  :D.
woodmills1
I like it, dead end dirt, off dirt, off dirt, :P
sorry first time I forgot my comma's
upsnake
5500 generac, tied to the house.
Have the owb in the winter, (so frustrating to have a wood burning thing, but no way to get heat).
And the sump pump in the summer to worry about.
Eventually plan on getting a whole house propane standby one.
I use a 6000 watt to run the furnace and the well pump and a few outlets and lights. I had a gentrac hooked up to an outside plug. We also have a gas light. Works real nice to light up the house with.Only used it twice in 12 years. I forgot what outlets we had wired with it. But I did put my circulators on a plug.I just plug them both into an outlet on the furnace. I could use a real small generator,if needed,just to circulate the water through my lines.
I plan to simply kill the breaker and backfeed into the stove outlets to run circulator and blower. Thats how we did it on my fathers OWB with no problems.
I need to do some research on a good generator.
NWP
^ That's exactly the same thing I do.  I made a pigtail with 2 male plugs that I leave in the door of the stove .
