roundwood framing joints
Started by fallenoak, January 01, 2015, 12:27:35 PM
fallenoak
I'm hoping to build a 10by20ft round-wood frame concurrently to building my little band-mill then side it once the mills sorted.
anyone done much work with round timber framing?
are there a lot of specialist joints?
just started using sketch up yesterday so ill try and add a sketch-up drawing ASAP of my general ideas
thanks
Sam
Heartwood
Hi Sam,
Yes, we use timber framed joinery with round material quite often. You can use either scribe rule or square rule, but scribing is generally preferred if you have the room for setup.
I suggest three resources:
I wrote an article on scribing joinery for round timbers in issue #78 of Timber Framing, the journal of the Timber Framers Guild. You could get the back issue.
Japanese techniques use a form of square rule with round timbers, and you could research a number of websites and books, such as Japanese Joinery by Yasuo Nakahara.
Take a look at the Log Construction Manual by Rob Chambers.
We do a one week scribing course at the Heartwood School that covers many of these techniques. I would also contact some members of the U.K. Carpenters Fellowship since I know some of them work in round material often, and it appears you're in Britain.
Chilterns
Hi Fallenoak,
No matter what technique you intend to employ it is important to ensure that load bearing faces are primarily made in heartwood i.e. sapwood should not form a substantial part of bearing surfaces especially in a damp / wet environment like Manchester. Some timber growing in the UK like Sweet Chestnut would be best for this type of framing as (like catalpa or Black Locust) it has only 2-3 years worth of sapwood.
You might want to review the roundwood work done by Ben Law in this respect.
Chilterns
fallenoak
Heartwood thanks I'll try and track down those resources over the next few months. great pics that you provided helps to get things clear in my head.
Chilterns i did not know that in regards to heartwood sapwood ratio, I've got access to about 4 acres of very unruly and dense woodland mainly ash, oak, and hazel and to be fair I'm looking to build a shed/workshop in the garden of a property I rent for as little £££ as possible. more than anything I'm just tryna learn the techniques, with a view to building a timber framed extension on a property I own in the near-ish future.
I know ash is prone to bug damage etc but how would it hold up for internal bits that won't get wet etc?
what about hazel?
had a good look on Ben Laws website at the property he build in prickly nut wood and I've loosely based my shed design on it
I've found a good resource for scribe rule joinery here http://www.traditionaltimberframe.com
there's loads of images that have cleared up a lot of questions I have about scribe rule joinery, more than anything I think I just need to get stuck in and start doing, make the mistakes, learn the lessons and improve.
have I got the basic process about right/
1.design and source materials
2.layout template on floor where I will cut joints
3. support timbers on platforms and use plum-bob to align them with template on floor
4. snap center-lines on the timbers markup to find centers and joint locations (probably before and during point 3)
5.use plum-bob compass etc to plot joints and align from one timber to its adjoining timber.
6. cut joints.test fit
7.raise it
I know this is a pretty simplistic description.....but am i thinking in about the right direction?
