Second thermostat trouble!
Started by Firewoodjoe, November 22, 2015, 02:14:10 PM
Firewoodjoe
I have a OWB and I installed a second thermostat to kick on only the blower to my gas furnace. That way everything was hooked up and workable year round. Propan, A/C and wood boiler. Well I had a furnace guy come and change the blower in the propan furnace last year. He screwed the wiring up and couldn't get all three to work. So I had him leave the A/C off. I've been trying to hook it up like I had it and no matter what I do when the second stat. turns on it turns my A/C unit on! What did he do! I just pulled the breaker to te Ac.
r.man
Normally there are thermostat connections for heat, cool, fan, and possibly others depending on the unit. Sounds like you are turning on the a/c instead of fan only. With the outer unit breaker off it would act just like fan only. Your a/c terminal should be attached to the appropriate coloured wire on the main stat.
Life is too short or my list is too long, not sure which. Dec 2014
