1st timer Makita DCS510 16" 91vx chain question
Started by MakitaCS, November 17, 2008, 03:05:18 PM
MakitaCS
I just got a Makita DCS 16" and the fella that had it had an Oregon 91vx 3/8 chain on it.
After checking out Oregon's website, it looks like that chain should be on a 41cc and under cs.
The Makita DCS510 is 49cc's from what I remember.
Does the 510 have too much torque for this chain?
It kicks ass. It cut through some oak. Not the fastest, but it did it quickly. The cutters are very small though.
Thanks bro's
CHEVYTOWN13
SawTroll
Information collector.
MakitaCS
10-4
I know I have to change the sprocket for that? Going to search.
Thanks man.
CHEVYTOWN13
MakitaCS
CHEVYTOWN13
ladylake
Bailys has a bar and chain combo on clearancefor $16.95    bcc 16 sj58   It's 325 x.058    Steve
RSteiner
I don't think there is too much difference between the Dolmar and the Makita if your saw is fairly new.  I beleive Makita owns Dolmar.
I run the 3/8" pitch chain on my Dolmar PS5100 which is about 50cc's.  The saw handles that size chain very well and I like the larger driving links and cutter size, plus the two other saws I have run 3/8" pitch chain which makes things easier.
You can switch over to .325" pitch chain by replacing the drive sprocket and the guide bar.  You may want to wait unitl you need a new guide bar before you change.
Randy
Randy
ladylake
I'd go with a 325 setup on a 50cc saw if your cutting hardwood over 8". I switched my Husky Rancher 55 from 3/8 to 325 and it cut a LOT faster in hardwood with the 325 setup.   Steve
MakitaCS
Thank you.
I caved in and got the 5100-3/8 yesterday after all the reviews and learning about Dolmar-Makita.
I've decided to keep the 3/8 on the 510. I believe I'll be able to use the same bars/chains for both.
Someday I'd like to just clean up the bad casting in the ports if any and gasket match the ports.
I'm thinking dual exhausts too. I have seen a 7900 with duals and it looked bad ass.
I don't want to get too crazy with the mods but I'd like to have a small sleeper 510. I really enjoy
this little monster.
I have never tuned a 2 cycle before and I'm sure I'll toast the piston quick trying to figure out how.
But that's for another day.
Bailey's looks cool.
Thank you all.
CHEVYTOWN13
