light duty by pass grapples
Started by h2ofwlr, December 26, 2017, 12:48:05 PM
h2ofwlr
Good afternoon.  Looking for some advice from others that have gone done the path of  searching for the best grapple to put on a mini excavator,  12k lb  machine.    Going to be used for handling small logs 3 to 12 inch  and 16 foot long  and piling brush. thanks for your time and knowledge. Mark
DDW_OR
following
I have a bobcat 331 and a E80. going to be putting a stroke harvester on the E80
saw this
https://forestryforum.com/board/index.php/topic,67465.0/all.html
mike_belben
If you are hand thinning dense small stems from around crop trees, id find a bypass shear.  They have a little stationary blade nested in between the grapple palm and pull the tree into it making your mini ex into a baby feller buncher.  Lift tree, swing around and lay it in a pile for the bobcat to grapple onto the truck.
But they cant rotate, pins are fixed in the stick so its a rigid head, not dangle.
Praise The Lord
North River Energy
Was at the big trade show in Boston right after Thanksgiving. Noticed a lot of those compact track loaders that the operator stands behind. Most were kitted with some variation of a bypass grapple. I think one brand was maybe Ryan's?
Anyhow, you might look into whatever is being used by the tree removal crowd, as many companies use those loaders with grapples to remove debris from residential yards.
chubby
Forum members actually get a 10% discount on FARMA grapples since they're a site sponsor. Complete kits for excavators are available.
https://forestryforum.com/board/index.php/topic,97870.0.html
h2ofwlr
Thanks  for the leads guys I will follow up Mark
47sawdust
I bought a Farma 34'' grapple w/o the rotator for my tractor.Right now it is hung from a 10k # lifting ring that I can lock  for picking up firewood logs to buck to length.Seems well made,made in Latvia.Mine is probably the smallest size.
Gallery is currently not available or I would post a pic.
Mick
