Need Some Input from builders/users
Started by Tryduck, February 21, 2017, 07:52:38 PM
Tryduck
New to FF , Thanks for letting me join the group.
Building a Band saw mill (2x2 sq tube) carriage 4' tall 4' wide sitting on 3x3 Sq Tube 4' Long which will end up with wheels on to roll down 20' tracks.The platform that will raise and lower is going to be 2'x 4' on I think either cable or acme rods(still deciding that also.I need some input on the wheel bearings and which design to go with. I was going to go with 22" rims that will cut down to 2"-3" wide (mill a crown on where blade will ride) to use as Band wheels or Just go with the 18.75 pulleys at surplus.com. I wanted to get input on which type setup to go with. Should I use the 4 bolt flange  ,2 bolt pillow block or Use a Automotive style 4 bolt Moog wheel hub bearing assemblies.
      I was going to use 2 bolt pillow block bearings each wheel if I used 2x2 for band wheels but then was thinking using 4/6" sq tube if I was going to go with the 4 bolt flange/auto hub assemblies. Which would be the better way to go to get longest life out of bearings possible.If I go with auto hubs I need only 2 plus one pillow block to support axle shaft/pulley on the drive wheel.The 22" rims I will have shaved the width on will bolt right to them and I can mill splines shaft to slide into the hub as they do with cv axle ends . The back side will go through a pillow block bearing to help support the pulley/belt tension. Other side will be a non driven wheel bearing assembly being it doesn't need a shaft through it. I was also curious what is best tension type design. If I go with the 4"/6" sq tube with Moog hub assemblies I will not need a support in the front of the band wheels like I would if I used the 4bolt flange or 2 bolt pillow block bearing setups. I will be taken a set of 22" rims and narrowing them until I about a 2-3" wide wheel , removing the lips that the tires seal to along with much of the rim width so that only the area inline with the hub is left, making a crow then where the band wheel will ride.
Tryduck
Also need to ask what type paint to use? I was thinking of sand blasting then using a type of epoxy primer and paint they use for horse trailers or normal 8-24' trailers when they come new. Color doesn't really matter as I am just out for protection against weather/rust..
Kbeitz
Any good automotive paint will work good.
If you'r not worried about color then go to a paint shop
and ask for miss matched colors. (paint that was mixed wrong)
I got my paint for $5.00 a gallon. They wont tell you that
they have to pay to dispose of it so they are glad to sell it.
If you need more than one gallon just mix any two gallons
together. Just make sure it's the same kind of paint.
Love machine shop work
and Wood work shop work
And now a saw mill work
DMcCoy
Paint - I use Rustoleum oil base but always with rusty metal primer even on new metal.  Because I am the "King of Cheap" I use open cell sponge packaging material with wooden clothes pins as a handle for paint brushes, cheap cheap cheap (Kbeitz?).  Color - I went with JD green and get more comments about the paint color than the mill.
Kbeitz
JD green paint from JD is some very good paint.
One coat will cover very easy. Top notch paint.
Tryduck
Any one here that repairs their own saw mills or built their own that could maybe give me some input on my build.
Kbeitz
Quote from: Tryduck on February 22, 2017, 06:53:08 PM
It's a long read... Building my mill
https://forestryforum.com/board/index.php/topic,82853.0.html
DMcCoy
I went with the 18.75" V pulley, B 57 belts,  2 - 2bolt pillow blocks, 1 on each side.  Each side is adjustable.  You will need to adjust them to run true to each other, both horizontal and vertical.  The blade should track, at full speed, with out needing guides, when you are not sawing.
I used 2" .120 tube for the whole carriage.  The frame that holds the wheels I used 2"  .250 wall.
I use a porta power for tensioning.
Hope that helps.
Tryduck
DM thanks for info , I went ahead and ordered 2 of them 18.75 today . figured for $64 wasn't a bad deal for them and could find another use down road if I didn't end up using them.I wanted to know about the belt.Did you heat up it in hot water or did it stretch that much and fit over the pulley and isn't loose fitting once it is on.Should I be looking for a normal belt or some special type belt to put on the band wheel pulleys.Like a neoprene or kavlar type belt?
Kb awesome build read, I got some questions answered just reading your build so thanks! What is the distance center to center on the band wheels ? Is there a "common" length blade I should be using that is obtainable most places in stock that doesn't need to be special ordered? Long read means lots of useful information to me so I don't care how long it takes me to read a build.Thats whole point I came here.For input and help on my first band build    :)
Tryduck
DMcCoy
Quote from: Tryduck on February 23, 2017, 12:13:02 AM
There are plenty of discussions about belts.  See the 56 or 57 post for starters.  I tried but could not get the 56 onto the pulley, even with hot soapy water.  I use standard B57's from Surplus Center and haven't had issues.  I don't saw commercially like MM but he uses 57's too.  Belts are cheap compared to the rest of your project and you can change your mind anytime.  Belts are also a wear item, needing occasional replacement.
Your blade question; I get my blades from Cooks Saw.  Very helpful people!  It's been so long I forget if I use a standard size or not.  Give them a call they can help you with your questions.  Mine might be custom as I remember giving them the range of adjustment I had in inches.  They then round up or down a 'tooth spacing' so that you will get even tooth spacing at the weld.  They will also need to know which side your sawdust discharge is.  Call them, you need that blade information for your wheel spacing and adjustment range.  Blades stretch a little and you want enough slack to get the blade on and off without force.
I built mine to have @4" of adjustment independent of the adjustment available on the bearings.  Those slots in the bearing I use to get the wheels adjusted.  The sliding end of my saw frame is the 4" I'm referring too.  Keep in mind that is 4" of rigid(or close) slack adjustment.  I used 2" ID receiver tube - the stuff they make trailer hitches out of, it's missing the internal seam.  Spendy stuff!
Ox
158" or 13'2" is a very common length.  You asked about bearings.  I would think an automotive bearing will outlast a pillow block bearing.  Of course, this is all relative to the quality of said bearings.  Your build looks good to me so far.
Joe Hillmann
For raising and lowering the head I would recommend going with some type of lead screw. I went with a cable set up because it was quick and cheap and because of the stops on the hand winch I can never get the head to the exact height I want and both sides of the head are never at the exact same height.  The cable gets the job done but it limits the accuracy the mill is capable of.
Kbeitz
If using a hand winch it should be worm driven.
You can get them cheap on E-bay.
JRWoodchuck
I used 1 1/4" 4 tpi acme rod with steel nuts seems to work good for me so far. Do mill very much though. Woodmizer uses chain to lift I believe. Which could be very accurate as well. I run the 18.75" pulley from surplus center with b57 belts I like them a lot better than the urethane 56's. The way the urethane sits in the groove it wouldn't center creating a lot of unnecessary vibration. Ended up walloring out 2 pulleys that I had to replace.
Joe Hillmann
Quote from: Kbeitz on February 23, 2017, 05:58:47 PM
That would help a lot but it still doesn't force each to be at the same distance from the bunks like leadscrews would.  On mine the vibration of the engine is usually enough for both sides to settle to about the same height but when I crank it without the engine running it is very obvious that is it is raising or lowering one side goes maybe 1/2" then stops as the other side goes 1/2" then that side stops and the first side goes again and on and on until I stop cranking it.
Kbeitz
Quote from: Joe Hillmann on February 23, 2017, 07:56:01 PM
That's why I put long tubes on my carriage. If it can't shift sideways then
it will stay flat. The longer the tubes the better your control. I  don't have
any problems keeping it level. One thing nice with the  worm driven unit is anytime you let go of the handle it stays right there. You don't have to worry about the handle coming around and smacking your hand if you let go.
york
Yes,longer tubes and you need angle bracing in upper corners of the head....Looks like you did not build the head tall enough...
I would not worry about what paint to use...
Albert
Tryduck
Have heard great things about cooks saw blades and their helping people so gave them a call about getting idea which blade and how long to use. Well I was not impressed at all with them! This woman answered the phone with a hello , so I asked if it was cooks saw blades , next I started asking some basic questions and this woman said Look we cant tell you anything how to setup your mill all we can tell you is how our mill is setup . We cant tell you anything about building your band saw mill ..... So I was very very very displeased with cooks saw blades. Was planning to buy the blades and guide setup from them but not really sure based on that first contact with that woman!! They cant be only one who sells saw mill parts so onward...
Tryduck
Thanks for worm gear info. This is way I was going but Worm gear will be driven with motor winch also.I will have power/battery and will be charging as engine runs. I may try to have a hybrid type system with a removable hand crank option just in case.
Ox
That's the first time I've heard anything bad about Cooks.  I've dealt with them in the past several times and always very friendly and helpful.  Maybe you need to ask to talk to the boss.  Many people have and he's given lengthy discussions over the phone about many different things about mills, even homemade ones.
Tryduck
York,  the great thing about steel is you can add or remove. Cutting the top and extending is not a issue. I noticed similar mills from members here are only 48" tall including the cross bracing. If Need be I will move head out further where band blade clears and can drop as low as the casters it uses to ride on the rails.This is just a trial thing and first build , I'm sure I wont get everything right and have to learn some hard lessons :). I am not planning to cut huge diameter trees but Down the road if I get the mill fever bug Ill build a larger mill for them monster trees.
Tryduck
Ox , thats why I decided on cooks because of the things ive heard about them. But I just got off phone with that older lady and wow I was not impressed one bit. Really made me feel like I should find another supplier right off the bat. She was not a nice at all and really bad bedside manner. It was almost like I was ruining her day just by calling her and asking any questions about mills ! Talked for maybe 2 mins and once she said we cant tell you nothing about building your mill all we can tell you is how our mill is, I said then can you at least tell me standard blade I should be building for that is made a lot. She then replied , I already told you we cant tell you how to build your mill so at that point I was so shocked I just decided to get off phone with them/her and choose another supplier for band blades/guides...Was not a pleasurable experience what so ever.Maybe I will try again later but not sure I am will to risk another conversations with that lady again!
Ox
Man, that sounds like stuff that's happened to me before with other businesses.  I remember how that felt.  I really do understand your anger and frustration.  I never talked to an old woman, it was always younger women who were very friendly.  I'm wondering if people called off or quit or got fired and this old biddy had to fill in and was all pissy because of it.  It's a shame.
I would encourage you to try again in a few days, maybe next week.  Cooks has good blades and guides and other parts, including whole mills.  Maybe if you hear that same voice (I doubt you'll forget anytime soon if you're anything like me) just hang up, or actually put her on the spot.  I've done this before and the results can be amazing.  Something like "Hi there - I called last week and I think it was you I talked to...I hope you're in a better mood today because the other day you were very rude to me and I don't think your boss would have liked the way you treated me.  Are you in better mood today?".  I've used this method before and the results are usually very good.  Only rarely will the gal deny everything but at least you get results in the end.  Keep us posted.
FloridaMike
The Cook's website store lists every length and size bands for all their mills and most other brands.  I think you can find (within an inch) from one of the mill builders.  Which allows you to just build your mill at the width that works best for you... and then check Cook's site to cross reference what mill's band is compatible.  My homemade project came in to be compatible with either a Timberharvester 16'8" x 1 1/2" or Husky 16'9" x 1 1/2".
http://store.cookssaw.com/band-blades/blades-for-cooks-sawmills/
Mike
