Lumber definitions
Started by Housewright, March 27, 2008, 08:54:23 PM
Housewright
Hi;
I am looking for sources (dictionaries and glossaries) of historically used lumber terms like: Board, Plank, Deal, Balk, Stave, and Cant.
The word plank is so basic but most dictionaries are extremely vague in there definitions. Do you make a distinction between hardwood and softwood when defining a plank? Is the word deal still used and does it still apply only to fir lumber? I am interested in there modern definitions and historical uses, especially in America. What would you call a hewn 7"x11" timber?
Thanks;
Jim
Housewright
Thanks Tom;
The Wood Handbook has a good glossary. I had not seen "flitch" before. I am still looking for several of my initial definitions, though.
Jim
you will find definitions of sizes within the handbook.  Anything thicker than 5" (the 7x11) is a "Timber", or defined by its use "cross tie", "Tie", "post", etc.  The Glossary defines a plank.  then there are boards (under 2" thick) and dimension(2" to 5" thick).  I've never heard Deal used as a lumber term.
Don P
Boy I have and have wondered what it was  8). I had assumed a pine from the context while reading documents from around the Revolutionary War period. That's cool to hear what it is.
Dictionary definition of Deal: a fir or pine board of any of several sizes
fir or pine wood
A wood that is easy to saw (fir or pine)
Adjective: That is a solid Deal Table. (all pine)
I guess that is the same language as Scantling (2x4), eh?
Dave Shepard
I've heard of "deal topped" tables before. Never knew what it meant.
Dave
raycon
Boat stuff. Balk can be a beam. Beam is the width of the boat balk is a beam/timber . When I hear someone use the term balk I think of a boat cradle and one of the principle members. Could be its a beam in a cradle or  timber stock. Could be I'm off  and this is just a term used locally....Also hear it used in pier construction but not often.
Lot of stuff..
Housewright
That is interesting that a deal can be pine too (at least in some locality). There is an intersting definition for deal in the Cyclopedia of Architecture available through Google books. It refers to a deal as being Fir only. I have also seen deal as simply a cut piece of lumber 3x9 to 3x10 with no reference to species.
Modern Practical Joinery by George Ellis (1908) has an interesting list of "Market Forms of Timber" including deal.
A Log is a trunk felled and lopped.
A Balk is the log squared by ax or saw.
A Plank in hardwood is any cut stuff upwards of 9 in. wide and 1 3/4 in. thick; in softwood upwards of 10 in. wide and 2 in. thick.
A deal is over 2 1/4 in. thick and less than 10 in. wide.
A batten between 1 1/2 and 2 in. thick and less than 9 in. wide.
A board less than 2 in. thick and over 6 in wide.
Die-square stuff is between 5 by 5 and 9 by 9.
Whole timber- uncut balks.
A flitch is half of a balk.
Quartering- 3 by 3 to 4 1/2 by 4.
Scantlings- misc. cut stuff.
A square is 100 sq ft
A hundred of deals is 120.
A  load of timber is 50 cubic feet
A float of timber is eighteen loads..
Ends are cutoffs of deals, planks and battens.
Poles are straight trunks free from branches and less than 8 in diameter.
Masts- ditto, exceeding 8 in. diameter.
And I'll add to this, Piles are square or round timbers driven into the ground. I do not know if there is a size limit.
Jim
