Please tell me about this
Started by rick f, January 23, 2013, 07:07:51 PM
rick f
Ok not the best picture to show it but what is the clamp on the side of the blade for ?
I have a guess but i'm not sure.
Thanks rick
664 clark skidder
1- 562 husky
1- 254xp husky
1 - 268xp husky
5040 kubota farm tractor
Ken
It's for picking up an extra tree on the way out the trail.
rick f
Thank you, Ken that is what I was thinking. I see them in for sale ads in Canada. What are they called or is it just a tree clamp?
664 clark skidder
1- 562 husky
1- 254xp husky
1 - 268xp husky
Andrew Lawrence
could you use it for a de-limber?
Lawrence Lot Clearing Logging                            To God be the glory
gwilson
There are some Youtube skidding videos which show a skidder carrying 3 or 4 logs out on the blade. Cant recall the video name though.
I was at a show in Bangor,ME. I asked the guy what it was. In a French accent he told me that was a de-limber. Than he said some have them on both sides. The one I saw had hyd lines to it. can't really tell on that one.
UN Hooker
   Also notice the shape of the blade,it's different than regular blades. I built my blade similar, only I use mine to lift logs that are frozen to the ground so Hooker can throw her choker under them.     UN
Retired Toolmaker/Moldmaker
C-4 & C5D TF - 5500 Iron Mule - Restored 4400 Ford Ind. FEL ex Backhoe w/custom built boom w/Valby 360* grapple w/18' reach - 920 Cat w/bucket & forks w/clamp - Peterson 10" WPF - LT-15 - Cooks Catsclaw & Dual tooth setter - many Husky saws
bushmechanic
I believe they are called recuperators and used to pick up lost lost trees that come out of the chokers on the way out.
Okrafarmer
Neat idea. But then, I guess the log rubs against your tires all the way to the landing.  :-\
Now selling Logrite tools!
Ed_K
 I figured they were for lifting to apply chocker and alignment on landing,move to diff. sort pile.
Ed K
Okrafarmer
Quote from: Ed_K on January 25, 2013, 08:14:37 AM
Probably could be used for that, too.
ST Ranch
Hello all -First off I am going to talk about skidding single leader softwoods and not multi-leader hardwood.
This devise could also be used for setting up trees along the skid trail when falling herringbone to skid trails in a partial cut.
I have a triangular tooth on the bottom corner of each side of my 6-way blade on my D37E crawler that I use for this. How I use it is -  when I am heading up the trail from the landing, I turn off the trail a bit, and retrieve the trees  that don't quite make it to the trail when falling.  I hook [or with this clamp grab] the tree top with the tooth and sqeeze it up to the C-frame and pull the tree back onto the trail so that the top lays across the trail. I then usually drive over the tree top and try to break the tip off [at about 4 inches in diameter] and break off some of the limbs so facilitate hooking the choker.  I will do this to all the felled trees as I move up the skid trail toward the back end of the setting. I turn around at the end of the trail and start down the trail with the mainline running out [after hooking the first tree in the drag to keep the mainline tight]  and hook up a drag of 10 or so trees.  - Basically this saves me stopping and pulling a choker and mainline out to each tree that did not reach the trail when falling.  Saves a lot of time and pulling mainline!!!!
Sorry if this is a bit long winded.  I would also expect the grapple would be real handy picking up strays on the landing or tops and slash - help keep the dirt out of the landing slash pile.  Tom
LT40G28 with mods,  Komatsu D37E crawler,
873 Bobcat with CWS log grapple,
