Pole ford suggestions?
Started by logman81, August 07, 2014, 09:01:51 PM
logman81
I'll be moving onto a nice firewood job soon and there is a small stream to cross to access the property. It has been approved to use a pole crossing and just wanted to get some suggestions on building the crossing.
Precision Firewood & Logging
thenorthman
Just a though but them plastic culverts are mighty cheap...
Otherwise lots of big sticks in the bottom smaller sticks on top, layer of landscape fabric, and medium layer of dirt/rocks... like lasagna only not very tasty...  Maybe a layer of rock on the bottom for firmness.
well that didn't work
jwilly3879
Lay a piece of cable across the ford before placing the poles. When you are done use it to pull the poles out.
logman81
I have a grapple skidder so installing and removal will be easy .
jwilly3879
That would make it much easier.
deastman
How far across the stream?  I've found the easiest way is to use timber mats, they're usually 12' or 16' long and will easily hold up a forwarder
Samsung 130 LCM-3 with Fabtek 4-roller and Cat 554 forwarder, Cat EL 180 excavator, Cat D3C dozer, Cat D7E dozer, '92 Ford LTL 9000 dump, Easy-2-Load 25 Ton tag-a-long, current project under construction: '91 Peterbilt 379 with a Hood 8000 w/extenda-boom loader
logman81
from bank to bank it's about ten feet or less and pretty shallow. ;)
logman81
Thanks for the help guys I hope to be on the new job in a week or so .
