Belsaw build
Started by glendaler, May 30, 2018, 03:24:52 PM
glendaler
I'd be fine with up in the center, at least it wouldn't teeter. I was pretty painstaking with the pulley setup, they're pulling as straight as possible. Those off bearing skids are meant to be plated in, I can see how a slab could sag and get jammed up on the far one. The don't say the devil's in the details for nothing. I can't really understand why the belt wont track. The arbor pulley has a nice amount of taper and it's tracking nice and straight, just off center as you can see in the pics.
Belsaw A10 circle mill,
moodnacreek
A mistake I have made with used flat belting was cutting a wide one into a narrower width. To do this you cut strips off both sides to keep the original center. Can you flip the belt? Can one pulley be moved in or out?
luap
Glendaler, getting that belt to track properly is no different than a snowmobile track, conveyor belt, or a sandpaper belt. One drum on one end has to be adjustable to be angled that essentially makes one edge of the belt tighter and the belt will move over to the opposite side. In your case the driving pulley is in the same plane as the saw so moving that one will affect your lead. Don't know what your options are there.
Trapper John
Glendaler,  I have noticed the idler (rider) pulley has a major effect on tracking.  It must be 90 degrees from the belt axis.  I had the same trouble but a lot worse but as soon as I changed the angle on the rider, no more problem.  However my rider was much closer to the driven pulley.    My 16' carriage  had a high corner on one end.  I simply made a cut into the bottom of the carriage where the angle started and bent it into plane.  A weld and my carriage was straight.  Plastic strips on your carriage will greatly assist the sliding of cants when setting.  I have noticed that the amount of force needed to set a cant is directly related to inaccuracy of the lumber.  Just the nature of a Belsaw I think.  If I am within 1/8 " making lumber, I am happy.
bandmiller2
Logs, especially heavy ones, should not be flipped on the belsaw carriage you must follow their directions and make log turners to save the pounding on the mill. The turners are flip up wedges that take the brunt of the impact of logs/cants flipping. Frank C.
glendaler
After closer inspection I think trapper has my solution, I'm going to shim the top of the idler bracket and I think it should push it inward. As you say luap, everything is already lined up so changing angles of shafts is a no go. Log turners will be in place before the big logs go on frank.
moodnacreek
Glendaler, some day you could make 45 degree hinged wedges that you flip up. They get bolted to the log deck skids at the carriage. They should have 'skate wheels' on them. Some of the old time sawmill makers offered them. The last pair I saw where marked Lane . I didn't consider your idler on the flat belt. They are very touchy.
bandmiller2
The wedges I have on my current mill I used heavy truck brake shoe cam rollers. You flip them up and pull the log/cant towards you it lands on the incline and slides right back on the carriage with 1/4 turn. Mine are mounted on top of two deeply berried sections of phone pole so theirs no shock on any part of the mill. My first mill used 3/4" round stock welded to the top of the wedges, worked as good as the rollers. Frank C.
glendaler
I've seen the roller types but thought the narrow contact surface would dent the big log when it comes falling down. Am I over thinking it?
Trapper John
I use wooden wedges surfaced with uhmw plastic and the logs slide OK.
moodnacreek
Glendaler, You can't worry about that. If you where doing something very special you would spike the cant hook at the end of the log/cant and do as much as possible with you hands, not use the carriage if rusty etc.
glendaler
New bits finally came, should help quite a bit.
glendaler
Taking a break from working on hay gear, mocking up the brow. The saw side will hinge but the far side will be solid, 3x3 i-beam, all mounted on pressure treated posts pounded in. Still have to fabricate the hinge and lots of bracing.
jimparamedic
Looks like you are well on your way. want a great project. And I see you are getting a little dust in you vains along the way.
jimparamedic
People are coming out of the woodwork with there belsaws and I love it. Keep these post rollen
glendaler
Yeah they're popping up all over the place! I got the brow beams all welded and mounted, just needs bracing and log turners. I ordered a belt splicing vise which should be in tomorrow and I can fix my feed belt. Back to some sawing after that's fixed, I'm trying to get the lumber sawed to start on the mill building.
glendaler
And now to try splicing a belt for the first time...
bandmiller2
Glen, I have a clipper lacer just like yours. When you cut the belting be extra sure its square and aligned in the lacer. Frank C.
glendaler
I used a square when I cut the belt and was very fussy with the setup and it went perfectly. Except I was too cautious with the length and it was too long, maxed out the feed lever and was still slipping. Shortened it but it seems like this old belt is made of something stretchier than the new one I got, I think it's about as good as it's going to get.
glendaler
Well I'm about 200bf in and I've made a few observations. The feed control handle needs to come out 4-6" at least, it's rubbing along the log when taking a wide cut and even got jammed up in a knot trying to go by, and it puts me too inline with the blade. Also I thought the dogs I had were superior to the newer style and I was very wrong. At least that's been the case with the small logs I've been milling. I can see me making my own dogs.
jimparamedic
Modifications are an ongoing part of a sawmill. live and learn my friend
moodnacreek
Dogs are tricky. The only dogs I have used that really hold in any wood are the screw dogs. They would never work on a Bell saw, too much force. You need side lever dogs that drive the spike and hold at the same time and are operated with one hand. Good luck .
jimparamedic
as long as you get a good grip about 1/4" penetration that should hold the log if then the dogs slip you have an alinement problem or you are trying to feed it to fast. each tooth should be taking 1/16" per revolution, wide logs you have to take less small logs you can take a little more. you just have to get a feel for your mill and know how it sounds. that is why even a fully auto mill still needs a sawyer
moodnacreek
Maybe I should have not said that because if you had under hooks a screw dog would not force the head block up.
Trapper John
I am depressed when I set my dogs and the knee  flops from side to side.  Something is just not right in my mind.
