not cutting same height
Started by REGULAR GUY, May 18, 2014, 02:34:09 PM
REGULAR GUY
I just started sawin again this year. I'm sawin 20' SYP  and there is 5/8" difference in thickness/height  from entering the log and the rear. All the rails on the mill seem to be level and aligned. The blade is the same height at all rails, the mill is level.  I put the log on the mill, take the first cut off the top, flip it 180 degrees, and whether I level the log or not the log (bottom "first" cut is setting approx. 5/8" off the first rail?????? Every log!!!  I'm thinking if feed to fast, dull blade etc. it would not be consistent, but it is. I can't figure it out. I see nothing in the book. I got a Timberking 1400 and seem to have checked all that is obvious but I missed something. Any clues ?  Regular Guy
REGULAR GUY
Me again, don't think I'm explaining good. After I take the top cut, flip the log 180 degrees, set the blade for 10", the can't at front will be approx. 9 3/8" while the rear (back) will be 10"s, cuz the front of log (where blade starts cutting) is off the rail that much.  rails are clean. This happens every log.    Regular Guy
sealark37
Borrow or rent a builder's level.  Set it up and level it 20-30 feet to the side of the mill rails.  Have a look at every point on your mill, measuring with a carpenter's rule.  Then, move the saw head down the track and make sure it stays along the same height.  If everything is parallel, then look somewhere else.   Regards, Clark
ladylake
 It could be stress in the logs, are the slabs bowing up when you saw, if so the log is bowing the other way and when turned from one side to  the other won't touch the bunk with the bigger end touching and the smaller end off the bunk. If you want true lumber you would need to take a couple of skim cuts.  One other thing is to make sure you don't have to much pressure on the center jacks, they should just touch plus another turn or 2 with the head in the center of the mill .  Steve
slider
Sounds like stress to me.But on every log ? If you have checked the distance from each bunk up to the band then like Steve said try flipping and skimming until the cant will lay flat on all the bunks.
al glenn
Nomad
Quote from: REGULAR GUY on May 18, 2014, 02:53:59 PM
Sounds to me like you've got logs with lots of stress in them.  Do you always flip the cant 180 for every cut?  I'd only do that if the cant was moving.
     If you flip the cant and the ends are raising, it's stress in the cant.  If you don't flip the cant, does the middle raise up?  Get somebody to stand on it while you clamp it.  The stress won't go away, but the board will still be even.
     I suppose I'm just reiterating what ladylake stated.  And of course, the longer the cants you're cutting the more obvious the error will be.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
POSTON WIDEHEAD
If the beds level......take a measurement from blade to bed starting off.......then run the head down the real AS IF you were sawing (without a log). When you get to the end, measure the blade height from the bedrail again...see if they are the same. This will tell you if the head is rising or falling.
Ga Mtn Man
Pull a tight string down the length of your mill to make sure your mill is straight.
ladylake
Quote from: POSTONLT40HD on May 18, 2014, 05:50:32 PM
The head cant rise or fall in relation to the bunks but if there is too much pressure on the center jacks it can cause  the center to hump up a bit which will result with the cant ends off the bunks on the ends when turned over.  Steve
BBTom
Quote from: Ga Mtn Man on May 18, 2014, 06:01:17 PM
I second the tight string test, first empty then with a log on the bunks.  If everything is right, you must have tension in the logs.
2001 LT40HDD42RA with lubemizer, debarker, laser, accuset. Retired, but building a new shop and home in Missouri.
POSTON WIDEHEAD
Quote from: ladylake on May 18, 2014, 06:31:28 PM
If a band mill has a positioning sensor, my Woodmizer does, and it starts going bad.......the head can rise and fall......I've been through it. When mine went bad, I had a 1/4" difference in thickness before I figured out what was going wrong.
5quarter
5/8" out of level on every log? I don't think it's stress (at least on the logs part). A log here and there, ok. But every log? something is either not right with the saw or the blade. Make sure you mill alignment is good as others mentioned. put on a new blade. make a cut and see what happens. Make sure your sawhead is not drifting up or down while in the cut. increasing the set will also help to make straight cuts in pine. If it is stress in the logs, maybe you're slabbing too heavy. try taking smaller bites off of each side and see if that doesn't fix it.
Blue Harbor Refinishing
Doug Wis
   I 2nd the thought of too much pressure on the center jacks. I bought a new TK 1600 3 years ago. We sawed an 18' white pine while the delivery guys were here. It came out exactly like you describe. Called TK and they really didn't have an answer. said to keep an eye on it and see what happens. delivery guys setup instructions were to make ground contact with the center jacks and give them 3 more turns. I have found that by doing basicly the opposite solves the problem. That is, make ground contact with the center jacks and then back them off a couple of turns.
A man who says he can do everything at 65 that he did at 25 sure wasn't doing much at 25.
ladylake
 Make sure to have the head close to the center when adjusting the center jacks.   Steve
slider
Are some of you saying that the main frame is flexing on his mill.May be tk needs to build a stronger frame.
al glenn
POSTON WIDEHEAD
Quote from: slider on May 19, 2014, 07:11:54 AM
i agree.
ladylake
 Yes the frame flexes some and so does your WM  mills or any mill 25' long.  There was a tread a while back of WM mills doing the same think if the jacks weren't set up right. If it didn't flex you wouldn't need jacks.  We don't need to start bashing TK or any other mill.  Steve
ely
put on an oak log and see if that does the same thing.... im betting its your blade and syp combo,
or just look and see if there is a buildup of sap/ resin on your band while sawing.
do you saw from the butt of the log or the top of the log.?
drobertson
It almost sound like an immediate steady constant dive that straightens itself out by the end, blade guide alignments could be the simple factor,
slider
I was not bashing TK at all.I think they are a good company but if flexing is the problem it should be addressed .Hopefully with closer attention to the stands.I have fixed this problem with flat bed trailers by welding a bridge under the rails.It will stiffen them up .
al glenn
ladylake
 Every 25'  long mill will have flexing and the jacks need to be adjusted right when cutting long . Not a problem that needs to addressed by TK as they build stout mills.   Steve
Blades often dive a bit when entering a log. I would check your guide roller alignment, make sure your blades have enough set, etc.  Wide cuts in pine can be a bugger.
QuoteI have fixed this problem with flat bed trailers by welding a bridge under the rails.It will stiffen them up .
Yes, stiffen them, but will not take out the flex when the trailer is loaded vs. when it is not loaded.
ladylake
 I've noticed flatbed trailers with 20" or so beams  arched way up empty and flat when loaded plus they bounce when loaded.  No such thing as long beams being 100% ridged.   Steve
backwoods sawyer
Guides would be the last place I would start.
I would start by moving the mill out, cleaning up and repositioning by the book then work my way up from there.
The carriage rocks the mill and if the ground under the one leg is not as firm as the rest :-\
I notice the front leg on my mill tends to work its way into the ground more then the rest. I have set the mill up in the morning and by lunch have to do a reset.
Moving the carriage on a soft set up you can have consistant measurement from the blade to the each bed rail as the weight of the carriage flexes the main rail as it moves down the length. I picked up a 20' 2x2 square tubing to check that all bed rails are the same hight, one being high will give you issues like this as well.
Backwoods Custom Milling Inc.
REGULAR GUY
I appreciate everybody's time and responses.  I've measured and measured the blade (with tension on it), to every rail and they all measure the same.  I'll try slabbing lighter as I've been just straight to sawin cants, and then into 2" by 8"s.  I've put a straight line across rails and all is good.  Yesterday I cut a 12' white oak log and it did the same thing, on different rails the front of the log was setting high in front...with a new blade.  By different rails I mean it was not the same rails than the longer (20') pine log.  I always kinda go slow into the face and after blade is into log speed up slowly to "proper' cutting speed. I'm not at all unpleased with the mill, it's a small (hopefully) adjustment somewhere just gotta find it. I'm thinking, as a few said, that it may be the center jacks to tight. I'll loosen them and clean up again the area.
If I am following what you said in the OP, the first reply, and again in your last reply, the log/cant is raising up off of the sawmill bed (rails) and causing the end to be thinner?  Is that correct?  If so, then you do not have a sawmill problem, you have a log with tension problem.
If you are slabbing straight to your cant dimensions, that could well be your problem.
REGULAR GUY
After putting the log on and doggin it down, I'll take the first cut, sometimes slabbing the first cut to the can't dimensions sometimes not, then flip the log 180 degrees to the flat spot on the rail/bed.  When I flip that log, it is setting approx. 5/8" off the rail at the face ( where the blade goes into the log), with the rest of the log laying flat on the rails.  I wasn't at the mill today to try anything new, but yesterday, with a new blade,  either with a 20' pine log or a 12' oak log, ( the 12' log positioned farther back from the saw head ), there was a gap between the log and the rail. For example, after flipping the log to flat spot,  I set the blade at 10"s,  cut the entire log,  and the first several inches of the log (where I first saw into it) is approx. 9 3/8" and the end (rear) is 10"s. I almost always position the log with tapered end toward saw head. This is baffling me, I'll try relieving the tension in the center jacks. Thanks again for all ya'lls input and help. Regular Guy
REGULAR GUY
Forgot to mention......I'll try slabbing different.  Thanks,  Regular Guy
Ga Mtn Man
In your post above you said "I've put a straight line across rails and all is good".  Did you mean to say you put a straight line across the bunks...?
Tom the Sawyer
Certainly a curious predicament...
With all the things you have checked this might be redundant but, who knows?  After your initial opening face, and before you turn the log, have you measured the height of the new face from each of the bunks?  Are they identical?  Have you checked the flatness of the opened face with a straight edge along its length?
Is there anything else touching the bottom of the log, either for the opening pass or after it has been turned (toe board, clamp, turner arm, etc.)?  Watch your clamp very closely as it contacts the log.  If out of adjustment, as pressure is applied it may be lifting the log slightly.
Hope you find the source, it can certainly be frustrating when things don't go as they should, especially when you can't figure out why.
07 TK B-20, Custom log arch, 20' trailer w/log loading arch, F350 flatbed dually dump.  Piggy-back forklift.  LS tractor w/FEL, Bobcat S250 w/grapple, Stihl 025C 16", Husky 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says, "He's sawin logs", I ain't snoring.
5quarter
Dollars to doughnuts Its you're sawing speed. If you are creeping into the log and slowly picking up the pace, you're going to see that happen on nearly every cut, to a lesser or greater extent. You should be entering the log at or near regular sawing speed. watch any production saw operate. it feeds at one speed from beginning to end. You may have to slow a little through large knots or max width cuts, but the rest of the time saw at the max feed rate that your saw will allow. you're blade is really designed to be pushed to its limit. You should get better cuts and more bf per sharpening if you maintain a steady feed rate through the entire length of the cut. just today I was sawing a practically petrified bur oak with a blade that I wasn't sure if I had sharpened or not. On my opening cut, I crept into the log trying tell if it was a sharp blade or not. turns out it was, but the resulting cut had dipped on entry about 1/4" for about the first 3 feet because of my dinking around trying to tell if my blade was sharp.   :-\
Anyway, give it a whirl and let us know how it goes.
LeeB
When you pulled the string line, did you block the string up an equal amount on each end, say 1/2"? If you have a slight bow down the lenght of the frame, you might not notice the string is being pushed up if you don't raise it slightly above the bed. You don't want your string to actuall touch the bed.
Brad_S.
My mill (Timber Harvester) was built with an intentional camber in the frame. It needs to be jacked up and supported on both ends prior to sawing. It is easy enough just to sight down the edge rails and see whether you have jacked it up level or if it still has a high spot in the center. I am not familiar with TK but imagine you can do the same.
My money is on the frame not being leveled crew.
ladylake
The easy way is to run the head too the front, if the back jacks are loose you have too much pressure on the middle jacks  Steve
terrifictimbersllc
The mill bed (tops of the rails) isn't necessarily a straightedge unless it is jacked to be so.  Imagine the mill bed is very curved or "crowned" along its length, with the mid-point being the high spot.  The head  tracks the curved rail so that the blade is always the same distance from each bunk.  That works fine for cutting flexible boards.   But the cant is not flexible.  So think of a curved cant now being flipped 180 degrees.  The belly of the curved cant is down and the belly of the mill is up.  Both ends of the cant are off the corresponding rails by a certain amount, or if one end is pushed down , the other end is twice as high.  Not hard to come up with 5/8" in 15-20 feet.  Nothing wrong with the mill.  Sight along the rails when jacking it up, and jack it so that the rail is straight along its length, not crowned or dipped.
drobertson
Four post mills must be very sensitive to being level,  I have to say, it is a head scratcher, if the alignment was good when the mill was put up, one would think it would be there when restarting.  Alignment can cover many facets of a mill, from the blade guides and parallelism, to bed rails and main frame.  This issue has captured my full attention for sure. I really would like to know the final result.
ladylake
Every mill has some flex in it and the jacks need to be set right when cutting long, plain and simple.   Steve
slider
I don't disagree with proper placement of the jacks .My mill is only a 20 footer but I have had it rocking on the center jacks due to soft ground and some laziness on my part and it has never done this.Sawing tension wood is a whole different story.I had some popular a while back that every cant was trouble.
al glenn
REGULAR GUY
Sorry fellas, I haven't been back for a while on the computer and started up again on the mill after doin other things a bit.  After trying different things,  I cleaned up the mill (underneath and around), changed my blade entry speed etc., and something was still  off so I retightened the jacks  makin sure the center jacks were not to tight (creating  a crown in the center), and after that,  the mill cuts great. That little crown in the center, (which didn't  show up when I measured the height of the blade on each rail ?!!? ), allowed for the second cut (180 degree turn) to be off approx. 5/8" because the log was above (lifted off ) the  rail nearest the cutting head 5/8". I hope my explaining makes sense. I thank you all for all your help and input. Regular Guy
9or
Thank you for following up with your fix.  Everyone, regardless of their sawmill manufacturer, learns when problems are identified and solved.  Every possible solution that was offered was the result of someone's experience with a similar problem.
The FF Encyclopedia Rocks.   :P   smiley_thumbsup smiley_thumbsup
drobertson
Makes perfect sense, hard to believe it took this long to figure it, not being critical, cutting methods can often times cause trouble shooting troubles,  glad you have it figured out,
reswire
I used to have a TK 1600 and never experienced that problem.  I never set up on a solid (concrete or the like) surface, always adjusted the bed as level as possible, and never had a problem.  I can't remember who made the post, but they offered the suggestion that you might have something under the center of your mill, propping up the cant.  Sounds reasonable.  I would also check for sawdust or other foreign objects that seem to accumulate on the bed rails; even though the head is extremely well built and heavy, you can have an issue with trash that is normal on all four post mills.  I also started into the wood slowly, and built up speed while sawing,,, no problems there.  I did have problems with the original blade guide assembly, but Timberking sent me new blade guides at no cost, which fixed a problem I had with wavy cuts.  Talk to Matt at TK, he is very knowledgable, and probably your best bet.  The mill bed is rock solid, never considered it to be, nor was it ever a problem.  If you bought the mill second hand, maybe the previous owner could shed some light on what he may or may not have done with the mill,,,, if he's honest.  Good luck
OOOPPPSSS!  Just saw where you figured out the problem.   I was reading from the start and skipped to "POST".    If you have any problems send me a PM, maybe I can help if problems persist.  I know there are a lot of TK owners on the forum, they are good mills.
Norwood LM 30, JD 5205, some Stihl saws, 15 goats, 10 chickens, 1 Chessie and a 2 Weiner dogs...
LeeB
Quote from: REGULAR GUY on June 02, 2014, 02:42:47 PM
9or
Using the blade to bunk measure will not tell you if you have a crown along the length of the frame. Pulling a string tight from one end of the frame to the other   and measuring to the bunks from the string will tell. Be sure to block the string up an equal distance on each end.
delvis
I would say stress in the wood, but if it's happening every log and it's only happening on one end, it's more likely the mill is not sitting true.  You can tell if it's stress after you flip the log 180 degrees and saw a few boards off, the front end should relax and settle toward the bed.
I had a Timber Harvester mill which was a 4 post mill and the rails needed be checked a lot when first setting it up on each job.
If you can get some machinists blocks that measure 1" to put on the bed rails you can run a string the length of the mill to verify whether it is sitting flat or not.
If I never saw another board I will at least die happy having spent the last few years working with my dad!
delvis
Quote from: LeeB on June 03, 2014, 07:30:09 AM
9or
You have to remember the head rides on the frame not parallel to it, so if the rail is crowned the head is going to ride it like a roller coaster.
ladylake
As mentioned earlier the easy way is to run the head all the way to the front, if the back jacks are loose the center ones are too high.  Really no need to run a string.  That little bit of flex can be used to your advantage when you are cutting stressed lumber and don't have any extra cant to do a skim cut as you can jack the back or front up a bit to make the cant lie on the bed.   Steve
