New Quote Functions
Started by testaccount, February 17, 2018, 03:32:39 PM
testaccount
I'm going to make a video tutorial real quick to demonstrate some of the new quote functions. They are pretty cool! Stay tuned!
testaccount
As promised! Now back to my alter-ego :D
Tutorial on Selection Quoting
sentence or selection quoting - YouTube
Tutorial on Multi Quoting
multi quote function - YouTube
Grizzly
Yep. Should save a bunch of editing. Thanks.
2011 - Logmaster LM-2 / Chinese wheel loader
Jonsered saws - 2149 - 111S - 90?
2000 Miners 3-31 Board Edger
Ljohnsaw
I accidentally ran across this function when I inadvertently highlighted some text.  Fantastic time saver!  8) Thanks Jeff.
John Sawicky
I will have to try it out. Thank you!!!
Banjo picker
testaccount that sure does look like Jeffs truck in your gallery. :D  Banjo
Quote from: testaccount on February 17, 2018, 03:32:39 PM
I need to quote my alter ego's post so he gets an alert, so I can do a short video explain some of those functions and settings.
Chuck White
I like it!
Makes things a little easier!
Banjo picker
I like it too.  And if I can do it anybody should be able to.  I could be the poster child for hard headed when it comes to tech stuff.  Banjo
Southside
High speed, low drag- thanks testaccount.
White Oak Meadows
PA_Walnut
That spins my propellor cap! Very cool...and convenient.
THanks! 8)
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Peterson Dedicated Wide Slabber
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Northland 800 Kiln
terrifictimbersllc
What's the "Add Multi-quote" for?
Kbeitz
I tried the new quote thing out today. I highlighted what I wanted to quote and moved down and typed what I wanted to say and posted it. The quote box came out empty with no words in it. What did I do wrong? Last message in this post.
This is the words I tried to quote.
Surplus surplus sales the 1-7/16 bore pulleys and pillow block bearings, but they don't sale the shaft that size. They sale it 1-1/2" with keyway. Can I have a machine shop turn down a 1-1/2" shaft to 1-7/16? Would this be a problem?
This is the message it happened in.
Back at the homemade sawmill in Sawmills and Milling
Love machine shop work
and Wood work shop work
And now a saw mill work
terrifictimbersllc
Am guessing that you highlighted the desired text, then hit the usual Quote button in the upper right.   To me it looks like that Quote button does the same thing it did before, not the new thing you were expecting it to do.
Instead, for the new function, it looks to me like one is supposed to highlight the desired text then hit the
" Quote Selection" button that pops up right on top of the highlighted text.
This is a tutorial on multi quote.  Different than the selection quote. Kbeitz, watch the videos. Its impossible to answer your question on what did you do wrong unless I was there.
terrifictimbersllc
Quote from: Kbeitz on February 18, 2018, 09:00:02 AMThis is the words I tried to quote.
I selected your words above, then clicked the popup "Quote Selection".  Then I typed these 2 sentences and posted.
Kbeitz
Kbeitz
Quote from: terrifictimbersllc on February 18, 2018, 09:27:44 AMI selected your words above, then clicked the popup "Quote Selection".  Then I typed these 2 sentences and posted.
And again...
Kbeitz
Sometimes it's just not taking... Guess I'll need to do a preview each time.
