450 Timberjack Skidder
Started by Mountain_d, November 19, 2013, 10:09:35 AM
Mountain_d
I am shopping around for a used skidder.  I noticed some good prices on a few 450 Timberjacks.  Does this machine have any inherent problems that anyone is aware of?  I seem to be able to get a good looking 450 for less money than a 230 or Clark Ranger.  Seems odd?
ED
1978 TJ 230E 3.9L Cummins 4B, Husky 372XP, Husky 61, Husky 266XP, JRed 625, Husky 265RX clearing saw,  Woodmizer LT40HD 1995, Kubota 4950DT (53hp 4WD), Wallenstein V90 Skidding Winch, John Deere 610 backhoe, 1995 Volvo White GMC WCA42T SA Dump Truck, 2004 Ford F-250SD 4WD, , Central Boiler OW
ga jones
What year? I just bought a 380c my one buddy has one and his buddy has a 450c. There good machines. The 200 series is out of this world price wise. Everyone wants those.the 380s and 450s are a lot bigger than the 200s. The 450 is longer.bigger axles than the 380. Most times they have much bigger rubber.
380c timberjack c4 treefarmer international trucks jonsered saws. Sugi hara bars d31 komatsu 350 tj grapple
Dave Shepard
That was my thought as well. Bigger rubber, more fuel, need more room in the woods. A friend of mine has a 450, said it will suck up a lot of fuel. I think he said 80 gallons a day, but that may have been the forwarder running too.
Jamie_C
There is no way that a 450 skidder could suck up that much fuel, even the older Tigercat 845 harvesters from the late 90's early 2000's would have had a hard time burning that much.
Dave Shepard
It must have been both the skidder and the forwarder then. I can ask the next time I see him. I just remember it was a lot of fuel.
loggah
 maybe a 450 grapple could use that much fuel ! ;D
Interests: Lombard Log Haulers,Tucker Sno-Cats, Circular Sawmills, Shingle Mills, Maple Syrup Making, Early Construction Equipment, Logging Memorabilia, and Antique Firearms
ga jones
Another friend of mine had a 460 grapple it used 45 gal a day.
ga jones
The first tank in my 380 was 1.67 gal per hour.ill keep you posted
cutter88
Quote from: Dave Shepard on November 19, 2013, 12:51:40 PM
no possible way it burns that much fuel if I work my 640d all day move like 70 trees skidding 3000 feet the most I would burn is about 130 letres
Romans 10 vs 9
650G lgp Deere , 640D deere, 644B deere loader, 247B cat, 4290 spit fire , home made fire wood processor, 2008 dodge diesel  and a bunch of huskys and jonsereds (IN MEMORY OF BARRY ROGERSON)
ga jones
130 liters that's a lot of soda! cause that's the only thing here in liters
ga jones
34.34 gallons for the rest of us
ehp
had a couple 450's , I sure would take a good one over what I'm running right now which is a 230 , If you push the 450 real hard in big timber I know I could not make it to 5 oclock on a tank of fuel but in most cases about 25 gallons a day would be a normal , I burn that in the 230 a day
ehp
is it a 3 speed or a 4 speed trans in it , I have had both
Kemper
I have a 460d grapple and I can run it from sunrise to sunset and not burn that much fuel.  Cost per ton I come out a head with big skidders. Need a good driver who can get big and heavy drags to make it pay off though.
Quote from: ga jones on November 19, 2013, 05:32:00 PM
rfm7fxfox
We own a 450c DA grapple and it does not burn a lot of fuel. I have not figured out how much a day yet but I run it all day, pull decent size hitches up  steep hill and I cant complain about its fuel consumption. But I also don't hold it to the boards while running the grapple, I like our equipment to last. Its got the 6cyl Cummins, recently rebuilt. I love the machine, runs 28l x 26 tires with bear paws on all 4. Has a 123" cat grapple on it from a 535, grapple is a little over kill for the machine but it'll pull a big hitch. Stable as all hell. Only had to use the locker once on it. Machine grips good, have no complaints as of yet, been running it for almost 2 months now. Still new to me but I love it! Dual arch is nice cause you have more reach and you can bring your hitch up onto the machine putting the weight more over your axle then off the back of the machine. It was definitely a smart investment for us! Good luck with your new purchase no matter what it might be!
Dolmar 7900, Ported Dolmar 7910, Ported Johnsered 2172, J-Red 2186, Ported Husky 385, Ported J-Red 2258,Tree Farmer C5D,Timberjack 460 D.A. Grapple, 2015 KMC 2500 Grapple Track Skidder and 2005 Peterbilt 379 Logtruck
Maine logger88
Ga jones does your 380 have a 6bt Cummins
Dave Shepard
Like I said, I wasn't entirely sure about the number, so let's not get too wound up about it.  ;) :) It is a grapple machine with a 6BT. Forwarder has a 4BT. I think it's a 610 TJ.
ga jones
Yes mine is a 6bt. My buddies 460 was a single action grapple 6bt and it was BAD on fuel. Maybe operator maybe pump setting maybe both.it was electronic.maybe that too?
ehp
all our motors are opened up on the pumps as we end up doing long skids with big hitchs as road cost is just way to high so we just pulled farther , Not all the time but I have seen mile skids lots of times and that burns fuel
ga jones
Kemper a 460 d is a deere engine and trans isn't it?
Maine logger88
That's a good motor I have one sitting in my barn id like to do something with someday! Ehp I have the same road problem as you seems like half the wood u cut is close to a half mile yard last year I cut a lot idk how far the yard was but it took 2 to 2.5 hours per twitch to drive in cut and drive back out and I ran 3rd or 4th gear on the 540 and burnt a lot of fuel doing it
Kemper
Quote from: ga jones on November 19, 2013, 09:19:37 PM
Yes, it's the same as a 648. Even has JD floor mats.
Mountain_d
Ok, thanks for the info on fuel consumption. It is a 1981. I am not sure on the engine yet but thinking a 453?
ga jones
Detroits are really good on fuel. Noisy( unless its a 453t )there almost as quiet as a cummins. Simple to work on cheap to rebuild.
Maine logger88
Did the older 450s come with a 453t
