PTO shafts, i need schooling.
Started by Satamax, December 25, 2017, 03:45:39 AM
Satamax
Hi everybody.
So i have this weird for me Rockwell T-case a T-226.
I want to use the main shaft PTO. But the PTO itself costs an arm and a leg, plus the rest! I have several other options.
One would be to use a declutch behind. But i need the slip yoke for the T case.
Does a Six spline  1 3/4" internal diameter exists in the agricultural world?
If anybody knows where to get one i would be very thankful. Even if there is some lathe turning to be done on the outside.
I have machinery. But i can't make the grooves Inside a bore, for the splines to fit in.
Thanks a lot guys.
nativewolf
Merry Christmas. Do you have a picture?  Having a bit of time visualizing it.
Liking Walnut
bushmechanic
Go to spicer driveline you will find what your looking for there. Applications for everything.
mike_belben
Grob Inc. will make you any spline and coupler combo you want.
Praise The Lord
Satamax
