Author Topic: new question about sawing wood see i am new to this  (Read 1135 times)
Offline 44woody
« on: March 29, 2013, 09:29:46 PM »
i read somewhere that somoene is spraying somehting on the wood before they sticker stack it. why they be sprayin it on there and what is it for.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: new question about sawing wood see i am new to this
« Reply #1 on: March 29, 2013, 09:45:49 PM »
To prevent insect infestation if the lumber will be air dried only and not heated in a kiln.  In some parts of the country, and especially in the South, powderpost beetles will infest your dry lumber and ruin it.  A spray can be made using a borate salt, Disodium Octaborate Tetrahydrate, mixed in water.  The borate is safe for most critters, but deadly for insects.
Offline 44woody
« Reply #2 on: March 29, 2013, 09:50:55 PM »
ok thank you very much  ill have to get me some of that stuff and make it.
Offline 44woody
« Reply #3 on: April 08, 2013, 04:50:20 PM »
someone told me to try bleach for the bugs an mold i tryed it the bugs left do yall think it well last to take care of them the guy said mix it three to one
Offline beenthere
« Reply #4 on: April 08, 2013, 06:46:38 PM »
The bleach would be good for the mold/mildew. That mix is plenty strong, as the mold is pretty easy to kill.
If I sorted out your sentences  ::) , I gather you think it chased off the bugs too? That would be interesting.
Offline Ianab
« Reply #5 on: April 08, 2013, 07:30:27 PM »
Like Beenthere said bleach should do a good job against mold. I'm guessing it will kill any ug you actually spray, but it's not long lasting. Once the bleach dries off, it's gone, and new bugs can come back. It also wont get any grubs that are deep in the wood. The mold isn't so bad, hopefully the wood gets dry enough before it starts to grow again.
The Borate is a salt, and it's left on the wood when the water dries off. This discourages new bugs from infesting the wood as they lay their eggs in that surface area, that's still full of Boron and is toxic to them. Even if you haven't killed all the larvae deep in the wood, you will have stopped them re-infesting it when they mature.
Offline 44woody
« Reply #6 on: April 08, 2013, 10:12:46 PM »
ok thank yall an wheir do i get this stuff from
Offline slider
  • sawyer,trucker,tree service
« Reply #7 on: April 09, 2013, 05:31:31 AM »
I think wdh uses solubor,any farm supply should carry it.
al glenn
Offline dboyt
  • Log On!
« Reply #8 on: April 09, 2013, 12:52:14 PM »
Some places spray anchorseal on the ends of the boards to prevent end checking, though this is usually done to the log.
Offline 44woody
« Reply #9 on: April 09, 2013, 01:38:26 PM »
will it work putting the bug stuff in the blade cooling tank?
Offline Red Clay Hound
  • Retired - Now Turning Logs into Lumber
    • Broad River Mobile Sawmilling, LLC
« Reply #10 on: April 09, 2013, 02:13:10 PM »
You need to soak the wood pretty good with the Solubor solution so I doubt it would do much good to just put it in your lube tank.  Only need to spray species that are prone to PPB attack like oak and hickory.  I don't spray my walnut, cherry, cedar or pine.
2007 Wood-Mizer LT40 Super Hydraulic with 51 hp. Cat; 2007 Wood-Mizer EG200 Twin Blade Edger; Woodmaster 718 Molder/Planer; Stihl MS460 and MS362 Chainsaws; 2011 John Deere 5065 with JD 553 Loader
Offline 44woody
« Reply #11 on: April 09, 2013, 02:54:03 PM »
ok  im new to this thanks red clay hound what bugs dont mess with the pine
« Reply #12 on: April 09, 2013, 03:43:13 PM »
I have never had problems with powder post beetles in southern yellow pine.  I know some on here have reported infestations, but I have not.  I have never found it necessary to spray pine lumber.
Offline WDH
« Reply #13 on: April 09, 2013, 08:29:11 PM »
The powderpost beetle that is so bad on hardwood does not infest pine (thank goodness).
Another Sawing Question
Started by Tree Feller on Sawmills and Milling
Last post October 09, 2012, 12:51:06 PM
by qbilder
sawing question
Started by furltech on Sawmills and Milling
Last post August 13, 2014, 01:36:56 AM
by furltech
Question about sawing
Started by GeneWengert-WoodDoc on Drying and Processing
Last post December 27, 2012, 02:59:52 PM
by Stephen1
Sawing Question
Started by Coondog Sawyer on Sawmills and Milling
Last post February 27, 2014, 12:29:05 AM
by 5quarter
