What should I cut from this monster white oak? video clip added
Started by GAmillworker, July 19, 2013, 09:17:39 PM
GAmillworker
Thank the Lord for second chances
POSTON WIDEHEAD
How about cut a new house.  :D
This is a WHOOPER!
nk14zp
Belsaw 36/18 duplex mill.
Belsaw 802 edger.
http://belsawsawmills.freeforums.org/
Quartersaw it   ;D.  You don't ever know when you will need some thin sliced quartersawn white oak to make a some engineered flooring  :D.
mesquite buckeye
That crotch is pretty big and if it is good, it could be really cool. If the butt of the log is solid, super cool lumber. How much hardware inside, though? We must be cautious. Also, that root ball is a killer. Don't let it get you. ;D 8) 8) 8)
GAmillworker
We will be bracing the root ball before we cut the butt.
drobertson
Bonified head scratcher for sure, I would cut some clear 1" off a few of the face cuts and see what is there.  Then make a decision on the rest, Happy for your in the sense it is already down and has to be dealt with, but not for the decisions from there,  20"'s and up quarter saw it,  should would be some nice ray and fleck, you might go grade till the tight knots show up then quarter saw,  should be around 12-14" , this will still give you a good 6" q-sawn board,  head scratcher for sure,    what a tree!  david
qbilder
Holy smokes somebody lost their yard in that root ball  :o Quarter saw as much as you can. That butt log is nice!!!
God bless our troops
Peter Drouin
A yard tree will have iron in it .And hart rot maybe. I would cut the hole thing into fire wood. And watch out for the root ball
Quote from: GAmillworker on July 19, 2013, 09:53:56 PMWe will be bracing the root ball before we cut the butt.
Cut the root ball off before bucking the trunk.  You may can brace it, but there is no way to safely support those roots.
rmack
If you can arrange it, might be a good idea to take a fire hose to the root wad before cutting it loose from the tree, may make it easier to separate the dirt from the roots than after it flops back down.
the foundation for a successful life is being able to recognize what to least expect the most... (anonymous)
Welder Bob
2012 LT40HDSD35 Yanmar Diesel Triple
1972 Patrick AR-5
Massey Ferguson GC2410TLB Diesel Triple
Belsaw Boat Anchor
Al_Smith
I don't think you'll need to worry about where that root ball will go .Gravity will put it right back from wence it came .Lawdy that thing has 5 tons of Georgia clay stuck to it .
You can probabley salvage some lumber but it really isn't a prime log  never the less it has some potential .
isawlogs
 White oak , quarter saw it, man that might have some of the nicess looking wood being that big, even if it does have center rot... does not matter center is not very usefull anyways.  ;)
  PLEASE.. WATCH OUT FOR ROOT BALL"  No bracing will hold that up, it will go back into its hole. While cutting log off of said root ball, be dam carefull, that thing is big and heavy.  :o
   Marcel
terrifictimbersllc
Should be enough wood for a composter or two in there, no matter what.
customsawyer
I did a job one time with a root ball that was smaller than that one. It had to be moved with a crane that had scales on it. There were bets as to how much it would weigh. It ended up weighing over 26,000 lbs. The point of this story is that you will not be able to brace that kind of weight, she will go back in her hole. You be careful they can be killers.
www.thecustomsawyer.com
ddcuning
I would quartersaw all I could. I agree with everyone else, that root ball is a widow maker! When you cut it make sure everyone is clear because it is going back in its hole and nothing is going to stop it. Years ago after a hurricane here in NC there was a story on the news where trees had gone over and a homeowner cut the trunk off and wasn't expecting the movement of the rootball. He wasn't aware that one of his kids was playing in the hole at the time and he lost a family member in the process of trying to clean up a tree.
Dave C
We're debt free!!! - Dave C, Nov 2015
RayMO
I cut hundreds of blow downs after a tornado a few years ago and the snakes just loved those big root/dirt balls  ;D Would be no sign of them until the saw was part way through and then they would come alive ! After most of 800 acres of damaged and or blow downs I decided If I never cut another it would be soon enough and then a friend had several nice black walnuts blow down and I said sure I will harvest them lol.
As for the tree in question you should have a better idea of what to saw or not saw after bucking. Some of the best looking trees can be rather poor on the inside and some rather rough lookers saw out beautifully.
Father & Son Logging and sawing operation .
5quarter
Peter... That's a load of hooey! you would not be able get that log on the mill fast enough... :D :D :D :D
Blue Harbor Refinishing
I have seen many stand back up with a butt log still attached.  The log then had to be felled.   :-\
That is a dangerous situation.
mesquite buckeye
I've had them go over to the log side. Also have had them roll and flip sideways. :-X
scsmith42
I would definitely quartersaw those logs.
Keep in mind that QS shrinks more in thickness than FS; I would recommend that you mill any boards wider than 8" at 1-7/16" green; they will shrink down to 5/4 after drying.
Wide boards often move a bit more during drying than narrow boards, and the extra thickness will help ensure that you can always make a 3/4" thick finished board, if not a 7/8" or 1".
Boards less than 8" wide can be milled at 1-1/8" or 1-3/16" in order to produce a 1" dry board.
Tom's 3638D Baker band mill
two-legged-sawmill
Hello, Too bad to lose such a nice tree, but that is life! If you
have plenty of water and a hose that will reach that far I
would start by washing a little at a time the dirt off the stump and root ball to fill up the hole before cutting up the main trunk! You will be amazed how the root ball will look minus the dirt. Also the stump can then be cut up one root at a time. God Bless and work safe!
"There are no secrets to success. It is the results of preperation, hard work, and learning from failures"
GAmillworker
I left log 17' 6" to get it cut & loaded safely. Once we got it back to shop it was more than the fork lift wanted to handle.  Cut crotch at 6' 6" which left butt cut 11'.  I've decided to quarter saw the 11' butt and slab the crotch.
isawlogs
 Nicde job, I see it sat back in its hole.  :)
   Marcel
I am glad to see that you handled it safely.   smiley_thumbsup
GAmillworker
THAT is a great video clip. Make a believer out of anyone thinking about cutting loose a tree tipped over with a root ball standing up.
Even with a good plan, that worked perfectly, everyone still jumped when it came loose  :D
Jemclimber
lt15
Seaman
Woodmizer LT40HD
John Deere 5310 W/ FEL
Semper Fi
Thanks for adding that video clip.  It will be good for "show and tell".   :o
newcomtd
NCDiesel
Quote from: Magicman on July 21, 2013, 08:35:49 AM
I watched a small pine stand up after just a few pieces from the top were cut.   It went up slow, so everyone was able to get out of the way.   I have also seen tree companies back the dump trunk up against the root ball to prevent a stand-up situation.   In this case, you may need to lay rails and back a locomotive up to it. (-:
NCDiesel
Cooks MP-32, 2016 Ram 1500, 6K Kaufman Equip. Trailer, 1995 Bobcat 753 skidsteer 1958 Ford 861 Diesel,
Youth Conservation Corps, Clayton Ranger District, 1977.
I worked sawmills as a teenager and one fall morning I came to work and smelled walnut cutting.  I have loved sawmills ever sinc
drobertson
Happy for you, love it when a plan comes together, looks like it's free of metal, no bluing in the butt cut,  heck of a log,  david
Magicman reminded me of 2 white pine that grew next to the road by the pond. They kinda grew out of one stump. There was only one root ball.They fell across the road and they cut the tops off and now there are two logs about 20-30 feet tall sticking up in the air.
Now that is one fine butt log.  I am  scheming on how to get it  trying to figure out how to get one like that  :D.
customsawyer
Danny if you figure out how to get it I'll cut it. ;) :D
Piston
Oh my god, I wouldn't have touched that log  :D
Way to go!
-Matt
drobertson
We had 150 plus blow downs from an 09' nader, a good friend has a big john deer skidder, he would grab the trunk, a few close to that size, and the balls would lay real nice back in the hole, a few hairs would raise, but all said and done all went well, including the sweat!  david
GDinMaine
It was crazy on so many levels, but I'm glad it turned out well.  I'm curious what is the length of the bar on your chainsaw.  That will tell us the diameter of the tree, as it seems you just barely missed some fibers in the center.
It's the going that counts not the distance!
WM LT-40HD-D42
