What to saw from spruce logs
Started by leeroyjd, March 27, 2017, 04:47:54 PM
leeroyjd
The 12' but log is clear and 24" . The rest of the logs are full of limbs but I'd like to use as much as possible.
I'm not a builder nor do I make furniture cabinets,etc.
I would like some ideas what to saw here.
We have a couple barns that always need different work as well as one unfinished addition that needs flooring walls, etc.
Thanks!
47sawdust
1'' boards for sheathing and repair work.You will always need 2x framing material.Look around at the buildings you have to see what might need attention in the future.The great thing about having a mill is you can saw pretty much whatever you want(need).I saw 3x4,3x6,and 3x8 for a variety of projects.I also saw 1/2'' stock for battens.
The spruce will bring out some colorful language so keep the mill running when swearing to protect the innocent
Mick
ladylake
  If you want to saw wide spruce fairly straight 3/4 pitch  Simonds blades work way better than 7/8 pitch, night and day difference.  The 3/4 pitch have a shallower gullet which after all these years I think saws straighter in hard to saw wood , more blade and less tooth to turn the blade.  Steve
