Very very very hard pine
Started by Clover, March 29, 2017, 08:18:59 PM
Clover
I don't think I'm ever going to get that blade sharp again. Only got a couple logs out of it.
Not to bad I almost all the way through LOL about 2/3rds. That's a one inch shaft
Home made 30 hp sawmill all hydraulic, stihl 026, 170, pioneer 65, John Deere 955 with home made forks. And a whole slew of other tools
jmouton
ya   thats not good,,i am surprised it went that far,,,
        jim
lt-40 wide ,,bobcat,sterling tandem flatbed log truck,10 ton trailer, stihl 075,041,029,066,and a 2017 f-350,oh and an edger
DPatton
May as well finish that cut before you sharpen😂
TimberKing 1600, 30' gooseneck trailer, Chevy HD2500, Echo Chainsaw, 60" Logrite.
Work isn't so bad when you enjoy what your doing.
D & S Sawmill Services
78NHTFY
...sometimes you get the shaft :D :D :D All the best, Rob.
If you have time, you win....
You use that for a log dog?
Seem like it's never done with a blade that is just about to be pulled off because it's all worn out.
paul case
Na it has to be a new one!
I usually throw in the towel on a blade that has hit metal that hard. Tin snips will cut it so you can get it out and put on a new one to saw the rod the rest of the way off ;D
PC
pc
4x4American
I like that shield over the guide roller.  My favorite saying when sawmilling: "Better luck next time" lol
The more better luck next time moments you have, the better you become!
Boy, back in my day..
newoodguy78
Sixacresand
When I had a WM LT10, it had square steel drop-in log stops.  I replaced them with oak the same dimensions.  I could just saw right through them and not tear up a blade.
Clover
Quote from: jmouton on March 29, 2017, 09:00:37 PM
        jim
My saw cuts pretty quick and I was really moving when things came to an abrupt stop. I've never seen a hydraulic mill before but the few people that I've cut for said my mill is the fastest one they've had cut for them.
tareece
I know how THAT feels... Blades and metal don't mix- for long!!! :D
Todd Reece
Lover of many things. Experienced in most... expert in few
dgdrls
Quote from: Clover on March 29, 2017, 08:18:59 PM
I know a member here who would take that band....and make it work!  :)
tareece
Quote from: dgdrls on April 01, 2017, 11:14:27 AM
Don't keep him a secret... I'd like to learn great sharpening tips!!!
Todd Reece
He can practice on the one that I hit a dry wall type screw with this morning.   :-\
Kbeitz
Love machine shop work
and Wood work shop work
And now a saw mill work
dgdrls
You're cut from rare cloth K    8) 8)
Best
D
tule peak timber
Kbeitz
I really wish I had every ones blades when you all was done with them as
long as they was not broken... People say time is money... well I got the time
to waste bring back a dead blade to life again and it makes me feel good that
I took something no one wanted and made it work again. If enough blade
would come in to our junkyard I would never buy a new one again. I just
keep working on them until I find out why they are not working. It's not a
waste of time for me. I was even welding the broken ones but I think that's a
waste of time because the silver solder just cost to much for all the short
time the blade last after welding. I think I'm getting really good at fixing
dead blades. I sure get enough practice.
Clover
Kbeitz are you still using an electric die grinder to sharpen? How well does that work?
Kbeitz
Quote from: Clover on April 02, 2017, 08:45:14 AM
I touch up with the die grinder and I would use it all the time if it wasn't
so hard on bits. It takes one bit for every sharping. I made a sharpener that I
use now out of a chop saw.
