Question for those that have centrifugal clutches on their mills.
Started by Modat22, December 05, 2005, 01:17:25 PM
Modat22
I'm trying to design a parts list for my bandsaw head. I'm thinking about using a 2 belt clutch "b" size for my mill.
I can request a clutch that starts to engage at a certain motor speed, What I was wondering is at what point on your throttle does your clutch begin to engage?
Another silly question. Is it better to drive one wheel over the other? IE. should the blade be pushed through the cut or pulled?
Thanks guys, I'm sure I'll drive you bonkers with question as I start building the beast.
ohsoloco
The clutch on my Norwood engages with just a little touch from the throttle.  If the engine is idling high for some reason, the blade will move as well.  I don't think you'd ever want to "push" a bandsaw blade through a cut, either.
IL Bull
Mine pulls the blade through the cut.  Has a manual clutch.
Case Skid Steer,  Ford Backhoe,  Allis WD45 and Burg Manual Sawmill
woodbowl
Centrifugal clutch, manual clutch .............. I don't even have a clutch. My WM-LT40 uses a belt tension leaver. Seems to work fine. What are the advantages or disadvantages of these?
Full time custom sawing at the customers site since 1995.  WoodMizer LT40 Super Hyd.
Husband
If you get a clutch that engages at approx 2000rpm you will be good to go. Most 4 stroke motors idle at 1350rpm and throttle up to 3600rpm.
The nice thing about the centrifugal clutches is that there is no load on the starter gear, engagement is nice and smooth, also that IF you got a jamb up, then the clutch kicks in saving belts and pulleys from glazing up and causing slipping druing normal milling.
Hope this helps.
Chris
Modat22
Quote from: woodbowl on December 05, 2005, 03:45:43 PM
I'm thinking about going that route as well, The clutch would make things simpler in my mind though and keep a constant tension from the motor to the driven pulley keeping any possible movement in the drive wheel to a minimum.
Cost is a consideration though, so far the only 2 belt clutch I've found is 260.00 from linnlumber saw mill parts. I also found one through boston gear but they've not emailed back yet with a qoute.
I'm also thinking about building in an emergency stop into the unit where the clutch would be nice to have.
Thanks for the input folks.
D._Frederick
Try a Google search, there are a number of companies that make cluches. You want to pull the blade for it to operate correctly.
logwalker
Hi, You didn't state your Horsepower. I looked for clutches this last summer and in the 20 and above range you won't find a good one for much less. Linn has a lot of good parts for homebuilders. I think they are good guys to deal with also. Just my .02's. good luck, Logwalker
wiam
I think Peterson runs a 3 groove clutch on their mills.  I have not asked what one will cost as I do not run a clutch on my mill.  Do not put a $60 clutch on your mill.  Don't ask how I know this. ::) ::)
Will
Modat22
Quote from: logwalker on December 05, 2005, 08:13:46 PM
The motor I'm rebuilding is 22 hp at 2500 rpm, I'm planning to change it out later to a lighter motor in the 30 hp range if I can talk a relative out of a Kohler twin block thats been sitting in his shed for 11 years.
logwalker
That horsepower puts you into the larger centifugal range. And if you up it to 30 then what.I would look at the motor mount lever that woodmizer uses to tighten belting for clutching. It uses a lever to over-center the adjustable arm and tightens belt. Works well and eliminates some problems. Logwalker
Modat22
Quote from: logwalker on December 06, 2005, 11:34:11 AM
That horsepower puts you into the larger centrifugal range. And if you up it to 30 then what.I would look at the motor mount lever that woodmizer uses to tighten belting for clutching. It uses a lever to over-center the adjustable arm and tightens belt. Works well and eliminates some problems. Logwalker
Hmm, do you think an idler/tensioner pulley would work or do you think that would add vibration to the assembly?
highpockets
modatt,
I just installed a centrifugal cluth on my saw. It is a 2 belt unit that I bought through Motion Industries for $315.00.  I did not know about linnlumber but their's seems to be the same clutch which is built by Osram Co.  I really like mine.  I used a solenoid off an old Kuboto diesel engine to throttle up my 20 h.p. Honda engine.
Louisiana Country boy
homemade mill, 20 h.p. Honda & 4 h.p. for hydraulics.  8 hydraulic circuits, loads, clamps, rotates, etc.
logwalker
The system woodmizer uses does not have idler wheel. They just use a lever to raise or cock the motor mount to tighten the belts. Very simple and the movement of the motor also advances the throttle with a simple linkage. Works great. LW
Modat22
Thanks guys for all the information.
I have to think about what I'm going to do, I like the idea of the clutch but hate the cost. I like the idea of the moving engine tightening the belt but my motor is so heavy it could be a problem.
I might try to machine a manual clutch that allows for slow start of the wheels or find a clutch off a haybailer that bolted on the same engine I have.
Thanks again!!
twostroke_blood
I wonder if someone could make use of an old Troy built roto-tiller to engage and dissengage?  Just a dumb thought.  Dont shoot me ;D
Minnesota_boy
Quote from: twostroke_blood on December 11, 2005, 09:46:12 AM
would you use the tines for a debarker?  ;D :D
woodbowl
Twostroke, there won't be no rounds fired from over this direction. I like that kind of stuff! If you think about it, that is the way an engineer would think. what is already availible - how can it be made to work? What erks me is, when it gets to the marketing level, things are desigened away from the practical way of thinking. Now the agenda seems to be lets design it so that it breaks at a certain amount of hours and designed in such a way that only ours will fit so they have to buy parts from us!
rbarshaw
Even with a heavy engine, cocking it to tighten the belts, or sliding it, is one of the best ways. No loss of power from idelers and just beltd to replace. The best way is a fluid cushion, ie; automatic transmission and torque converter.
Been doing so much with so little for so long I can now do anything with nothing, except help from y'all!
By the way rbarshaw is short for Robert Barshaw.
My Second Mill Is Shopbuilt 64HP,37" wheels, still a work in progress.
tnlogger
Quote
now i've used them to run hay elevators,once hooked one up to a saw table.
but as a debarker we might have to get arky ta hold the thing cause he is da man  :D :D :D :D
gene
