Guess weight of monster oak log
Started by Joey Grimes, May 13, 2018, 05:36:39 PM
Joey Grimes
 a customer delivered a oak log to me it' is 57" in diameter at big end 12' long the hollow is 7' in then solid I know the weight because they have the loaded weight and the empty weight but I want to see what everyone else thinks weight is beacause I was shocked!
94 woodmizer lt40 HD kabota 5200 ford 4000 94 international 4700 flatbed and lots of woodworking tools.
ladylake
muggs
I will guess 5284 lbs.  Muggs 8)
Ljohnsaw
I could do it the Price Is Right way and guess 7501# but I'm thinking more like 8,500#.
SawyerTed
It's awfully hot here (90+) to be thinking of such a log.
My WAG is 9,400#.
CCCLLC
Guessing that the hollow center is deceiving. #6950
scsmith42
I would put that log somewhere between 8,500 - 9,500 lbs
Tom's 3638D Baker band mill
tule peak timber
firefighter ontheside
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
12,000 pounds.  Maybe 12,750 pounds.  If it is less than 11,000 pounds, I will buy you a coke.
kelLOGg
GAB
Depending upon the moisture content and the species of oak:
Somewhere between 8,500# and 13,000#.
GAB
POSTON WIDEHEAD
300.......I mean it does have a hole in it. DUH!!!!!
Blonde Goat
Chuck White
According to the "log weight" scale in the tool box, it's weight is: 13,396.32, but that's without figuring out the rotted part.
I would think the rotted part would have been around 300#, so 13,096.32 pounds!
mike_belben
Praise The Lord
Joey Grimes
The log weight was 15,240 lbs!!!
Busysawyer
What kind of equipment did you use to move that thing?
mike_belben
Praise The Lord
Joey Grimes
We couldn't handel it we shoved it of trailer where it was going to be cut
kelLOGg
That was going to be my 2nd guess ;) What's in the hole? concrete?
SawyerTed
CCCLLC
Are you sure you didn't have your foot resting on the scale?
POSTON WIDEHEAD
15,240? Wow !!!!!!!!
There's probably metal in it.
Someone must have laid a V-8 against it years ago and I don't mean Mater Juice.
materhead
mike_belben
Lol.. It swallowed the dozer it sprouted up under.
Praise The Lord
Crusarius
next question is what mill is it going on? be nice to know how well some of these beds handle a log of that size.
