Norwood Owners....Please report!
Started by inspectorwoody, December 10, 2005, 10:20:03 PM
inspectorwoody
Have been looking at the Norwood and it seems like a nice setup for the money. Would like to hear all the pros and cons...from the mill to the customer service and everything in between please  ;)
Gadget
It'll do the job..... unless ya have real monsters!
Customer service was great.
Mine is a much older version, and I bought it used, in case it matters. ;)
PawNature
Mine is a Mark IV. I am just a weekend sawer and don't need or want anything more. I love it for what I do. Never dealt with customer service.
GOVERMENT HAS WAY TO MUCH CONTROL OVER OUR LIVES!!!!
sawwood
Inspectorwoody JR has the MarkIV and you will see it when you come down
to have a look see at our lumber. It is a good saw that will do about as
much as any mill. The only thing is the small width between rollers. JR's
will only cut a 18" width. I think the newer model will cut widther. WE have
cut a lot of wood on it and have even cut some logs longer then the bed
lenth.
Sawwood
Norwood M4 manual mill, Solar Kiln, Woodmaster
18" planer/molder
ohsoloco
I have the Lumbermate 2000, and I think the throat opening is something like 22 or 24 inches.  It's a great little mill, but the saw carriage tends to shake and shimmy when cutting real wide stuff.
Cuts great lumber, but I have problems cutting small timbers...because of the clamping system I never end up with square 4x4's
dail_h
   I use mine almost every day. While it is not the ultimate mill,it is probably one of the best mills for the money.NO SERIOUS COMPLAINTS,THE ONLY REAL ONES ARE THE LUBE SYSTEM,IF i HAD IT TO DO OVER AGAIN,i WOULDN'T EVEN PUT IT ON,JUNK RIGHT OUT OF THE BOX. tHE SECOND IS WITH THE 23 bRIGGS,i HAVE TO BE CAREFUL i DON'T OVERRUN THE CLUTCH,AND MAKE IT BURN. (oooopps) Customer service is outstanding.
   If I was going to buy a manual mill tomorrow,it would be a Norwood...
World Champion Wildcat Sorter,1999 2002 2004 2005
      Volume Discount At ER
Singing The Song Of Circle Again
moosehunter
I have a 2000 with the 23 briggs. I believe the clutch problem is that the clutch was designed for the 8 or 13 horse models and is not enough clutch for the bigger motors. I also have trouble with head shake in big logs. It will cut 24" wide. It makes beutiful boards. Great customer service ( even if they won't admit the clutch problem) ;).
I still think for the $$ it is a great saw.
mh
Higher than my expectations
whitey
   I have the 2000 with 9hp honda  wish it was 13 hp  I use it to saw western juniper for my cabinets and furniture. well worth the cost paid for itself first year  custumer service is excelent . didn't like norwoods blades went to woodmizer but that a personal  problem. for a small mill you won't go wrong with norwood.
           Whitey
you  don't have to be crazy to cut juniper but it sure helps !
Weekend_Sawyer
Mine is the 2000 wih 20 hp Honda engine, it is a fine manual mill, I have made lots of nice lumber, we sawed my brother's monster barn, all the lumber for a 20 x 25 addition on our cabin including bord and batten siding.
Many other small projects for neighbors and friends.
Mine was delivered in 27 boxes and pallets. The rails were the hardest part to get laid out. Now I could assemble them much faster.
I am looking forward to sawing a millshed for it, hopefully, this year.
I like my norwood.
Jon
Imagine, Me a Tree Farmer.
Jon, remember, You LOVE your Norwood. :)
Gabby
Great saw for the money. Before I bought mine I did the "Ben Franklin" close. Again for the $$$$ the Norwood beat the other 8-10 other mills I looked at. If you purchase I highly recomend air tools for assembly.
Never enuf time
JP
I have the LM2000, 23 briggs-several extensions. the mill will do everything the biggies do ,jest a little slower. fun to run, make modifications to, etc. If the cants are coming out out of square the dog posts are adjustable or the operator isnt clamping properly. ( ive been there//)  ( I suspect they will be dealing with the clutch problems soon)  JP
Norwood lm2000,Newholland 30 hp tractor, log carrier/winch, log arch  JP
DeepWoods
 I also have the Lumbermate 2000 with the 23hp briggs. I will say that although it has a few small problems, ( Lube tank valve really needs improvement), I am very satisfied with the lumber I have produced with it. I really enjoyed assembling it myself and feel for the money it was my best choice. I have no regrets with my decision to go with Norwood. I have only had to call their customer service once, and was satisfied with their response. They have even called me (unsolicited) to see if I was satisfied with everything.
Norwood LM2000 with 23 HP Briggs and 21 foot track, Hand Built Logging Arch, Cooks Cat Claw Sharpener and Setter. 48" Xtreme Duty Logrite Cant Hook.
Joel Eisner
I have 1/2 of a LM 2000 with the 13 HP engine (purchased it with a friend).  I love it.  I have cut most of the timbers for our 22x40 timber frame coach house (https://forestryforum.com/board/index.php?topic=15403.0) including the flooring, siding, shingle siding etc.  With about 30 hrs on the clock it has paid for itself.  My bigest problem is having to finish cutting all of the timber frame joints for our project and get back to running the mill.
Joel
The saga of our timberframe experience continues at boothemountain.blogspot.com.
Weekend_Sawyer
I have a hard time expressing emotion...
YES JEFF, I LOVE MY NORWOOD!!
An I don't care who knows... kinda.
JP
Jason_WI
At the bottom of this previous thred there are my modifications for the water lube system.
https://forestryforum.com/board/index.php?topic=3938.0
Jason
Norwood LM2000, 20HP Honda, 3 bed extentions. Norwood Edgemate edger. Gehl 4835SXT
inspectorwoody
Thanks for the replies everybody. Makes the decision a lil' easier with all the positive responses.
Gadget
treenail
I have owned a lumbermate 2000 for almost five years. It has been a great one man saw and has done most everything that I want it to. Have made money sawing other people's logs for cash, made custom flooring, clapboard siding, dimension lumber, turning blanks, etc, etc.  The saw has paid for itself over and over again.
Wouldn't part with it.
Treenail
Norwood Lumbermate 2000 sawmill , Ford 4wd tractor,Grimm/Leader maple sugaring equipment, Ford F-350 12' flatbed truck
Welcome to the Forum, Treenail.
I have an 83 year old friend with one and he loves it too.
I'm impressed with the workmanship of the fabrication.
Ironwood
Inspector, I don't own one but one of the guys I hire does. He........... doesnt care for it as I would but I really like it. We have cut lots of lumber with it. I have a few other sawyers I use, one with LT15 another with a Timber Harvester, another with a Hudson. I have used all of them, The Norwood really impresses me. I don't think you would be dissappointed. Reid
OLD_ JD
by using only 13 hp honda engine can u saw hard maple ???and how much bf of hard maple u can saw in  hour ???
canadien forest ranger
whitey
  Old_JD
    Not much hard wood around here  but I have sawn  big leaf Maple ,elm',.black walnut , english walnut . No large stuff mosty yard trees for freinds  10-16 inch 4 -10 ft long . I have the 2000 with 9 hp honda  working by myself I average 80-100 bdft hour not real fast but beutiful lumber. beats a chainsaw all to h---.
       Good sawing and happy holidays    Whitey
Weekend_Sawyer
Buy the biggest engine you can. You will not be dissapointed. My 20 horse Honda bogs when when you first open a log. after you have a squared cant it really rips through.
I saw everything from pine to Black walnut. The hardest thing we milled, actually most tedious, was a huge white oak. We had it in 18' long lengths, had to rip it into quarters with the ol 066 then even with a Skid steer to load and manuver it was still allmost too much to mill. The lumber we got out of it was well worth the effort though!
Jon
Flyboy
 8) I bought an LM 2000 in Oct. 23hp Briggs. Love it!
Real simple, Tough, and fun to make additions for.
Flyboy
A "Good Old Jack" -  DT 7500 Kubota 4X4 Farmi Winch - Norwood LM 2000 Band Mill - A Good Son, A Good Dog,
