bear paw chains or diamond studded
Started by minn firewood cutter, February 22, 2015, 12:46:56 PM
 which do most preferr bear paw or diamond studded? Thanks
Ed_K
Both, paw's on front, diamond's on back. best of both worlds.
Ed K
ForestFox
I would agree with Ed K. Rings up front and Ice chains on the rear. This with the proviso "wear what ya brung". If you got a great deal on a used set then whether ring or ice I'd make those work. Buying new you get exactly what you want!
TJ225,MF481 wLoader, JD792, MF1080, Husky 2100's,285XP,576XP,261,
Polish Hammer
I put the a heavier set 5/8 chain of bear paws on the front to add weight it helps with steering and keepint the nose on the groung when pulling big hitches. I run bear claws all around for now and will be switching to eco tracks when these chains are done. The eco tracks are more money but far better than chains. http://youtu.be/nejzVj17CwY
Cat 322c fmhw with waratah 622, Komatsu PC200-7 FM with waratah 622b, Timberjack 450b grapple, timberjack 660c grapple, Tigercat 630c grapple, John Deere 853j Buncher, echo saws
