Glue- Titebond, Quick and Thick
Started by caveman, June 12, 2018, 08:03:25 AM
caveman
Yesterday, after doing some tractor work for my uncle, who is president of the local woodworkers club, he showed me a glue that I was previously unfamiliar with - Titebond Quick and Thick.  He spread a little on the end grain of two pieces of oak that were about 3/4"x1 1/2" x 1 1/2" and clamped them together for 10 minutes.  I tried to break the glue joint with my hands to no avail.  Thinking I might have been suffering from girly hand syndrome, I took a 1"x 3" and whacked it a few times while holding it in my left hand and did not break the glue joint.
He was given a few sample bottles of Tite Bond glues at the last woodworker meeting by the Tite Bond rep.  It may be a useful product for those glue joints you don't want to wait on.  It is listed for interior use.
Also, the rep mentioned that cutting boards glued up with Tite Bond III were okay to put in the dishwasher (not that I would ever put a wooden cutting board in a dishwasher).
Caveman
69bronco
Never seen it in the store, that'll will be handy in places for sure!
DPatton
I have seen it in the store but didn't know of its capabilities till now. Good to know.
D & S Sawmill Services
btulloh
Good info.  Sounds like it could be great for trim.
Have to try that end grain thing myself just to see what happens.
HM126
Bruno of NH
As a finish carpenter for many years that would be very helpful while doing trim work.
21incher
That looks like it would be great for picture frames. Thanks for sharing.
caveman
I was thinking it would be good for picture frames too.
Caveman
POSTON WIDEHEAD
Thans for sharing this Caveman. New to me.
petefrom bearswamp
What is the work up time?
I am slow and clumsy so need a lot of time before set up.
I remember as a kid there were samples of 1" wood dowels glued end grain in our local (long gone) store.
The proprietor challenged us to break them apart, but they were so short you couldnt get a decent purchase
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
logbyr
I think if they changed the name to titebond board stretching fluid they would find a huge untapped market.
caveman
Update:
I asked my uncle to do another test of the quick and thick. He glued two 1"x4"x8" oak boards together on the end grains, clamped for 20 minutes.  He put a fulcrum on a bathroom scale after the 20 minutes had elapsed and he reported that the glue joint failed at 40 lbs of pressure as shown on the scale applied to the ends of the boards.
Next, he glued the same sized boards together in the same fashion and clamped for 24 hours.  He tried to break the joint with his hands and then over his knee but was unsuccessful at breaking the glue joint.  I don't guess he put pressure on the scale after the longer glue up.
Peter, I think the set time is relatively quick - like a minute or so.
Caveman
I do some segmented wood turning.  To make the rings a board is cut into pie shaped pieces and glued back together.  Its all end grain gluing.  An example is this bowl.
The majority of the time I use Titebond Original.  I can glue a ring and put it on the lathe to be turned after 10 minutes but to be safe I normally wait 15-20 minutes.  And yes the end grain joint is not as strong as face grain.
One method I've used with glue ups is called the Rub Joint.  The joint with glue applied is rubbed together for 30 seconds to a minute.  At some point the joint will grab and can no longer be moved.  Trim carpenters use this method a lot.  Again standard Titebond Original.
I don't think I would pay a premium for the new glue unless it could do something I can't do with the standard glue.  Of course I would gladly test a free bottle of the new stuff. :)
