Whatcha Sawin' ???
Started by Magicman, December 23, 2014, 12:00:38 PM
Quote from: doc henderson on February 15, 2019, 01:29:10 PM
Quote from: WV Sawmiller on February 15, 2019, 10:27:16 AM
  BTW - if I put a seat on my mill do you think a pretty young lady will come run it for me like they must do for you? It would probably be worth upgrading mills just for that. :D I better hush. My wife may see my comment. It is her 35th anniversary of her 29th birthday today so I better behave.
No! lol
Doc,
    You better be careful. You know I am real sensitive about negative comments like that and you would not want to see me angry.smiley_bull_stomp
Darrel
Quote from: terrifictimbersllc on February 15, 2019, 11:40:59 AM
Quote from: Darrel on February 15, 2019, 10:33:59 AM
Quote from: Darrel on January 25, 2019, 10:54:24 PM
Well if you've got the plaque in the LAD, da man will probably at the very least give you a medication with a generic name ending with "statin".
Lipitor is brand name for the generic name of simvastatin. Stay healthy sir.
Simvastatin is Zocor (Merck).  Lipitor is atorvastatin (Pfizer/Warner Lambert)
Yes, at some point I knew that. Should've looked it up before I posted.
1992 LT40HD
Quote from: Magicman on February 15, 2019, 09:51:29 AMI am now taking Lipitor for cholesterol, but all of this is good news to me.
Common side effect of Lipitor is joint pain. Only affects some people, but if your shoulders etc start hurting, go back to your Doc and they can try a different drug.  It certainly didn't agree with me, but Doc switched me to Pravastatin which seems fine.
Lipitor is the most common Statin, works for most people, and is the cheapest, so that's what they give you first. But if you are in the ~10% that it causes side effects for, there are other options.
Well at least then I would have something to blame aches and pains on except Birthdays!!  :D
Tuesday and Wednesday continue to look like washouts next week so I'll probably postpone next weeks road trip continuation until the following week.  It's hard for me to justify spending time in a motel on the customer's dime and not sawing.  :-\
DPatton
Lynn,
Glad to hear the good news and that all is well. Happy sawing!
D & S Sawmill Services
Crossroads
It's good to hear that you've got a clean bill of health MM. I got a call to mill up some Doug fir into 2x12's I'll need to cut 100 of them if this snow ever stops. We've got over 2' this week, so it could be a bit before I am able to get the mill out.
LeeB
Most welcome news Lynn. Glad to know your Timex is still wound tight.
PA_Walnut
I'm gonna kickstart the weekend posts with some awesome and wide cherry milled yesterday. More on deck for today.
Fiddling with new WM 7° blades...lots of chatter. Not sure if some set is out of wack, straight outta the box (going to check some this AM), or the dust is piling-up under the blade due to going to slow. Anyone?
LT40HD Wide 35HP Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Northland 800 Kiln
Wow, you jump started with some purdy Cherry.  I'll be anxious to see what you turn out today.  :)
Sawing speed looks too slow to me.  Also be sure that your blade tension is wound tight.
LeeB
Only time I ever had that was with blades that were way over set.
7° Turbos will with hard logs and too slow sawing speed.  I am sure that PA will experiment with his speed today.
YellowHammer
PA,
How wide were the cuts?  7° .055 ?  Turbos? Cherry should cut like butter.  Packed sawdust means lots of gullet spillage.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
PA_Walnut
Well, I agree that it would seem to be packed dust under the blade. I ordered 7° NON-TURBO blades, but I think WM sent me Turbos anyway.
I GUARANTEE that if I push the turbos to the speed that they want on a full width cut, they will not perform...been there done that. Carbide is the only solution I have found thus far, which is why I asked for standard 7s.
This is what my "non-turbo 34's" look like on the gauge at 7°. I guess you get Turbos whether you want them or not.  :-\
Northland 800 Kiln
gww
I posted yesterday but guess it got lost.  I just wanted to congratulate Magic on the good doctor report.
Cheers
gww
Thanks to all for their well wishes.  Just getting good reports removes concern which in turn makes you feel better.  This all began with precautionary heart tests, not pain.
Next weeks sawing is officially cancelled so I am now looking to the 25th for my next sawing.  I am hoping that I can finish that job in a week.
Jim_Rogers
I cut two posts for a timber frame repair project. they were 7x7x9'
he came and got them today.
Jim Rogers
GAB
Quote from: Bruno of NH on February 15, 2019, 07:01:14 PM
MM
I'm on the same med
Watch out it can bind you up☹
It does me and I have never had that problem before.
I do not recommend taking something for insomnia and for the bind you up syndrome at the same time.
Gerald
richhiway
Cut these oval pine cookies from a big crotch. Hope they dry without cracking to bad. They are nice table material. Cut a bunch of 2x6 and 6x6 hemlock also.
Woodmizer LT 40
New Holland 35 hp tractor
Stihl Chainsaws
Ford 340 Backhoe
Old Greenhorn
Well my mill is pretty much snowed out until it melts, I ain't sawin' nuttin', just plowing today, but the grandsons are here and they wanted to go down to the mill, and do some sledding, so we did both.
OG, looks like you might have the fixins for a little bon fire if the grand kids get cold.  rich those need to dry a little slow and out of the sun and further wetting like rain ect.  I had good luck with cottonwood in a container that is kept constant humidity.  outside they split like crazy. cotton wood get a bunch of tiny end grain cracks.
Waiting for others to get pics to me of the sawing part of camp Alaska this past weekend.  her is our fire barrel with a retort inside making lump charcoal/activated charcoal.
there is locust wood in the barrel it starts by boiling off the water and you get steam, in this pic we are past that stage and producing volatile gas that burns.  In the absence of O2, we will be left with 99% pure carbon.
That is a combine wheel burn barrel and a 30 gal mobile oil container with the lid on.  takes about 6 hours.  This is what is left.  use to make steaks or filter water and such.
I or my son will pack this in #10 paper sacks that will just fit in the chimney charcoal starter with a few wadded up newspapers.  Hotter but does not last as long as briquettes.
It will be interesting to watch those ovals richhiway.  I have some Honey Locust cookies drying that hopefully will make a bench back.  Guess that if they crack it will be a cracked back.   ::)
MM you may have to see a chiropractor to get your back cracked!!! :D
rich, I know those are pine.  here are pics of cottonwood left out and some in my container.
been in there a few years, nice and flat.  your crotch grain may give you some trouble.  I wish you well.
