sawing 3to 4in diameter cedar
Started by fivedogs, April 12, 2013, 08:21:35 PM
fivedogs
I had a guy  call me the other  day wanting to know if i could saw cedar poles in half  they are about 3 to 4 inches in diameter  the only way i can think of  is to sandwhich them between two  4x4's  to get a grip
i worry about twist out
any one else have any ideas ?
  thanks fivedogs
mesquite buckeye
And maybe put a tapered board underneath to compensate for log taper.
Cedarman
Take a 2x6 with the 2" part being the width of the rail.  Cut a V notch in the 2x and bolt a couple small boards to the base so the 2x6 will sit on the cross rail and not fall off.  Make 2 of these.  Now you can place the pole in the V notches.  If you need height adjustment at one end or the other, place shims under the appropriate 2x6.
Have a helper push down on the far end of the log holding it in the V.  As you saw down the log, place your hand on the log with down pressure and have the helper get out of the way.  You can quickly saw logs in half this way.  We have done many hundreds without incident.
fivedogs
Thanks for the advice  i will try both ideas  this coming weekend
thanks  fivedogs
