band roller
Started by slider, April 21, 2010, 07:13:21 PM
slider
Anyone fabricated a band roller ? Just curious,I have never seen one.I would think you would need a convex wheel against a concave wheel or vice verse. In order to push past the curve and let it spring back flat.Wish I could see one of cooks rollers close up.If you could just roll the band between two flat wheels under pressure perhaps some of us wannabe fabricators could pull it off. I have a cats claw sharpener , and well worth the price.    al
al glenn
Slider,I've thought about the same thing,some of the guys here have cooks rollers hopefully they will clue us in.Hopefully the slight crown could be ground on a sealed ball bearing.Frank C.   Oh and welcome.
Brian_Rhoad
I'm working on one made from a sheet metal bead roller I bought from Harbor Freight. I plan on using a flat roller with a bead convex roller to flatten the blade.
sdunston
I am in the process of putting one togather made out of an old PS&W edge roller, I have to finish the guides and mount it on something. After seeing the videos that Tim Cook puts out I can see the need for one. I know myself I have sharpered and set bands and they still want to dive and after putting a straight edge on the band I see why. We are on to something good here. If the one I put togather does not work out I am going to get one from COOKS.
Sam
WM LT28, American fordge 18x8 planer,Orange and white chainsaws, NH TC33, IHT6 dozer, IH-H tractor and alot of other stuff that keeps me agravated trying to keep running
Sounds risky but I wonder if one could be made to use on the mill  install from the back would take little pressure to straighten a running band,or probibly safer pull the band around by hand.Frank C.
ladylake
Running 1-1/4  x  42 blades my sharpened ones cut as good or better than new right down to the end. This band roller thing might be more for 1-1/2 blades that would cup easyier.   Steve
sdunston
All blades cup after a while. My metal cutting bandsaw with 3/4 blade cup at the same time they go dull but theyn are unsharpable. I have found that 1 out of 4 band blades for the sawmill that I have are cupped, but right moneys tight so if I cant build a roller I will have to go with out.
Sam
ladylake
Mayby the cup doesn't matter much on 1-1/4" blades, it sure doesn't on mine.   Steve
backwoods sawyer
I spent many hours hammering large bandsaws, so when I find an issue I just lay it out on some flat steal and straighten it out with a brass hammer and a straight edge under good light. Rolling them is faster but hammering is even more accurate with less cost.
Backwoods Custom Milling Inc.
sdunston
Quote from: backwoods sawyer on April 25, 2010, 01:40:51 AM
I agree that hammering would do the job but by rolling the band it also add strength to the back of the band acording to tim cook.
Sam
backwoods sawyer
Correct, straight steel will have more beam strength then curved steal, it is just the path that you take to get it there that is different.
ladylake
To me anytime steel is bent on way then back it loses strenght.   Steve
Dan_Shade
you're referring to "work hardening", ladylake.
I wonder if the increased performance due to rolling the band offsets the possible shortenend lifespan.
lots of dull bands and chains
ladylake
It can't here, I have no trouble cutting straight untill they break. Maybe a little trouble in big frozen knotty burr oak but brand new bands don't do as good.   Steve
backwoods sawyer
The ones that I hammer have been in a wreck and would not go back on the mill the way they are. I have one saw that came off the wheel when trying to back out of a cut, it had a kink in it but other then that it was a good saw, 15-20 min on the bench and it has been cutting good ever since, I have sharpened it 7 times since it was wrecked. When I am getting ready to set the teeth on the saw I place a straight edge on them and if I can see light under the straight edge I hammer them if they look good then I leave them alone. I find that I only hammer one or two saws each time I sharpen 20 saws or so.
Backwoods please tell us more about your small band benching.How heavy a brass hammer and its face shape.Do you extend the bands teeth over the edge of the steel "anvil"so you  won't take the set out??I have a hard time understanding why the spring in the band dosen't return the cup after you hammer it on a flat surface.How far apart do you make your hammer strikes and how do you determine the force of the blows??Sorry for so many questions but I'd like to try it on problem bands.Frank C.
slider
good questions ,frank c  . can"t wait for the answers. For those that never had a problem ,I want to be clear ,it only happens occasionally  with me but I want to know why thease things happen and how to fix them.This hammering is interesting.   al
al glenn
ely
like slider says, it only happens a few times, but without the band roller those few bands would be useless to me for sawing.
i have a few customers whose bands seem to need rolling more than mine. but i feel like they push their bands more than i do. meaning i change my bands out before they get very dull. that way it only takes one pass to sharpen it back to where it needs to be.
logwalker
It is hard to understand this band rolling issue. The bands are pulled over the wheels with considerable tension. But the cup across the band body actually points down making the blade dive. Is this the same results that other people get? I am using 1.5" blades and for awhile I thought I was having a problem with this, but I adjusted my setting process and the problem pretty much went away. I was getting too much set on one side and causing it to dive.
Joe
ely
on my mill when i get a band that is cupped it starts to rise then imediately dives away from the guides, once it dives it stays diving as long as you want to push it, until it breaks or comes off the wheels.
i think the pressure against the guide rollers stops it from rising more than it does and it has no resistance to diving and just pulls away from the guides.
backwoods sawyer
I use a light weight square headed brass hammer for hammering the saws. I have a piece of long heavy flat bar that the saw lays on. I do not swing the hammer but rather drop and bounce the hammer along the ridge over lapping as I go. I check for flatness then roll the saw on around a bit until the entire saw is flat. Good light behind the straight edge allows you to see how you are doing. Do not dent the saw, just tap-tap-tap the saw.
Bibbyman
How do you detect that a band is cupped?  I've handled untold number of blades and don't remember ever seeing one that is visibly cupped – even ones that don't want to cut even if they're sharp.
And once you find a blade with cup and you roll it,  how do you measure or test if for flat?  Could you "over flatten" it and make it crowned?
What if you took a cupped blade and flipped it inside out and put it on the mill,  tighten the tension way up, and then ran it for a few minutes?   (obviously you couldn't cut that way – don't ask me how I know)  Is there any chance that may take the cup out of the blade?
Sawing since '94
kelLOGg
Quote from: Bibbyman on April 27, 2010, 03:26:18 AM
What if you took a cupped blade and flipped it inside out and put it on the mill,  tighten the tension way up, and then ran it for a few minutes?   Is there any chance that may take the cup out of the blade?
That's an interesting question. Can Tim Cook chime in here?
slider
Bibby man the bands that I was having trouble with did not show any cupping either but when I checked the raker teeth (straight teeth),I found out that it was running about 7,000 ths to one side.I did this by checking with a dial indicator on both sides of the same tooth.I guess this was causing my set to be 7,000 more on one side.Pearsy has an old post on this under band rolling.I like your idea on flipping the band and running it. al
al glenn
ely
when my equip came from cooks, there was a short piece on blank band stock in the box. i use it for setting my setting machine dial idicator, and i also use it as a straitedge for checking flatness on a band. i always run it crossways on the gullet to the back of the band and check for light shining underneath the straitedge. that will show if the band is cupped or crowned.
i had a few bands that would not cut at all, when i learned about the band roller from cooks i tried it and it worked extremely well.
understand me on this. i bought the equipment as a package deal , i used the sharpener and setter first. the band roller never got unpacked for the first 3 months. i was under the impression i didnt need it. all my bands cut better than new when i got done sharpening them. until one day i had a band show up that had me pulling hair out. i finally hung it on the wall and painted it so it would not be used again. the set and sharpness was perfect on it. just would not cut straight. i accumulated about 3 of them over three months time. one day i read what the cooks boys wrote about band rolling so i got it out and set it up. i really had no idea what i was doing nor did i have any faith in it. but when i pulled the band off the roller i sawed perfect lumber with it. the other two cut just the same after rolling them.
just my opinion, the band roller is a vaulable tool when it is needed.
