540a axle trouble
Started by teakwood, September 15, 2014, 06:08:29 PM
teakwood
Hi guys, i am new here.
I have a worn Ring gear and pinion(Spiral Bevel) on the front axle of mi deere 540a skidder. Does anyone now were i can find a used one? they have to be matching units.
I have a complet spare rear axle and i was quiet happy when i looked to the Ring gear as they are in perfect condition. turns out that both axles are identical, just the Ring gear and pinion are right and left handed (right hand front, left hand rear. so i can not use this spare parts because its a rear axel pinion. I need the front one. thanks for any answers.
Maine logger88
Welcome too the forestry forum! Where are you from I know a guy who is parting one out he would probably sell the whole front end but depending on where you live it may not be worth it
teakwood
Well, I live in Costa Rica, so anyway i would have to ship the part to miami and have my local export agent shipping it down for me to Costa Rica. so i will be just interested in the two parts. Anything bigger, like a whole axle, would be to expensive to ship. Thanks for you help
Maine logger88
Well I guess that wouldn't work then. You could talk to Harolds Logging in Hampden Maine I am sure they could get you what you need
teakwood,welcome to the forum.
teakwood
thanks for the info. Another question: I need the brake shoes and parking brake shoes. Where can i get them? John Deere dealer? or are they other options?
Maine logger88
For my b I have got them from Harolds. Deere  sells them too but there a lot more $$$. I believe the brakes and different in a A tho mine are in the rear and front end. Are yours in the back of the trans?
teakwood
Thanks I will give them a call. On each axle they are 2 brake discs on on the left on on the right. this discs are being pressed be 3 shoes and on brakeplate. I need the fiber on the shoes and the three fibers on the plate. so they are 12 fibers on each axle. the hand brake is in the back of the transfercase.
Maine logger88
That's the same setup as my b make sure you get the rivets too
teakwood
Maine logger88 can you get me an email adress of harolds? I found the direcions in the web but no email adress. thanks for your help
Maine logger88
I will call them tomorrow and get an email and pm you with it or if you want the phone number I can give you that
