Testing out my new Grindlux sharpener
Started by Novascotiamill, December 18, 2017, 07:58:36 PM
Novascotiamill
Hello folks
I finally got a chance to set up and tryout my new grindlux sharpener from woodland mills. It took about an hour to put together and another two hours to get it set up properly,the directions are vague and I didnt have access to the internet. My first blade was a lennox blade that woodland mills sells in bulk,I dulled it sawing some pitchy hemlock. When i sharpened the blade at the 10 degree setting on the sharpener the angle looed slightly off,need a protractor, anyway I set the blade to sharpen with the auto stop set up,its really boring watching the sharpener! The auto stop worked fine.
Today was a nice day so I decided to saw some oak slabs,after the blade on the mill got dull I swapped in the one I had sharpened and it cut like butter,no diving or wandering,however I did notice it seemed to dull quicker than factory sharpened.
   I give the grindlux a thumbs up ! Now to consider a tooth setter and learn the science.
2017 HM130
Stihl 261
2010 F150 xtr
Lots of rigid genx5 tools
1 long haired german shepherd
2017 kioti ck2610HST with FEL and forks
Grindlux band sharpener
Wicked 55" root rake grapple
O
Drax52
That is great to hear :) I just bought a HM130 and have been sharpening by hand with a Dremmel. Takes forever to get it right. Will definitely look into buying the Grind now.
HM130, Dolmar720si, small Craftsman chainsaw, Alaskan milll, New Holland 1925
Kbeitz
Nice but I see it does not do 4 degree blades... That's what I use.
Love machine shop work
and Wood work shop work
And now a saw mill work
Chuck White
goose63
I have done over 200 blades with my woodland sharpener so its payed for its self.
Welcome to the Forestry Forum Drax52
goose
thank you to all the vets
rusticretreater
Quote from: Kbeitz on December 18, 2017, 08:44:18 PM
There is just not a detent hole for 4 degrees, you could drill your own or find the proper angle and simply drill through the tang and box body and insert a self tapping metal screw.  I use the screw along with the detent hole.
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
Tristen
The Tooth setter is just as important as the Grinder.  I have found (or it maybe just in my head) that the first and second sharpening's don't last as long as the factory grind.  But the third sharpening, and any you get after that are just as good or better than the factory grind.
Interest; Wood mizer LT35 HD,   Husky chainsaws, Firewood, sustainable logging, lumber, Kubota compact tractors
"You are the first person to ever see the inside of that tree"
