Cat 51 hp. Headless cat
Started by MartyParsons, September 06, 2015, 11:06:06 PM
4x4American
Well all my dreams have come true then!  I was under the impression that it was one or the other.  If you ask me the lt70 should naturally be a wide headed super.
Boy, back in my day..
petefrom bearswamp
Great info Marty.
Had I known in 2008 that the engine was Perkins I would not have gone for the diesel.
On the sawmill exchange which I havent visited lately, I used to see for sale diesel  powered mills with several thousand hrs on them with an engine practically new.
My mill has only 900 hrs on it but I will check the gasket anyway.
By the way my manual called for an amount of oil which way overfilled the crankcase.
I cant remember the amount called for in the manual.
Another issue is cold starting.
I have to block the throttle slightly after glow plugs are used or it will stall a few times.
But being a snow bird now cold starting wont be an issue.
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
Dave Shepard
Quote from: petefrom bearswamp on September 15, 2015, 08:41:51 AM
Great info Marty.
I noticed the same thing on the exchange. Made me nervous, but I've run mine since new, and it seems to be OK. Doesn't start like a Kubota, though. :D
4x4American
We've been running schaffers 5w30 in our diesels at work, and they've been loving it.  I guess schaffers has done some figuring and come to the conclusion that in the newer diesels they can handle the swap from 15w40 dinosaur to their 5w30 synthetic
Banjo picker
Pete on the oil capisity,  if its like the 62 on my mill, part of is because you cant completely get all the old oil out.  Another goofy design by Perkins.  I try an siphon all out i can but its hard.  Why would a company put a oil pan on a motor an not put a drain completely on the bottom?  Banjo
Peter Drouin
Quote from: coalsmok on September 14, 2015, 09:43:48 PM
Pete a head gasket is pretty simple with a manual listing tourqe pattern and amounts.  My coworkers and I can knock one out on a cat in ~4 hrs. Just put everything back where it came from.
I can do it, But I was going to drop off the mill and go to the Fair  ;D
petefrom bearswamp
Banjo,
I dont think that the drain on mine is a problem.
It is on the bottom of the pan on mine.
I had a guy tell me that you should run the oil for up to 1000 hrs as the blackness means that the oil is penetrating the casting surfaces and will work better.
sounds bogus to me.
I'll check what I have found on capacity on mine when I get home from having fun t my hunting camp over the  weekend.
BTW I use Shell Rotella exclusively in my diesels.
Kubota 900 RTV
Dave Shepard
I agree with the bogus assessment. :D Diesel engine oil has additives to deal with the sulfur in the fuel. Once those additives are used up, you need to replace the oil. Oil doesn't really go bad, but it does become filled with contaminants. Some diesels will run clean oil, some turn it black right away.
Peter Drouin
I don't know who, But thanks for the card from Foley Engines parts for my Perki- Pillar .
And they have Rockford Clutchs for my chipper too.
slider
Thanks for the post Marty.I just finished the head on my 62 horse cat. I first got suspicious when started seeing carbon deposits under the oil cap and the oil was getting dirty too soon. I pulled the rocker cover and found crud in the #2 lifter bore where the gasket failed.
This engine did not skip,nor smoke and had good power.
I knew there had to be junk in the oil pan so I pulled the engine and removed the pan. It was ugly. I also welded a bung in the bottom of the pan where it should have been to start with. Now when I change oil it all comes out.
In stead of pulling the oil pump I installed a oil pressure gage at the block and have 56 lbs of pressure so I think I am fine.
Check out the pic of the pan and how much oil is left after a service.
If anyone is going to do this be warned. This fuel system is difficult to bleed out. We finally had to use a gas rag to get it going.
al glenn
MartyParsons
Hello,
   Yes, Yes, Yes. Remove the oil pan if there is carbon in the head. If you are risking it and have not changed the head gasket and open the valve cover fill port to add oil. Always look for carbon deposits. If you see them it may be to late. The oil pump is in the front cover and it has steel gears in the aluminum housing. It does not take much of the carbon to do the deed, then on to the crank shaft and THEN to the oil filter and it is too late to help anything but a paper weight.
Glad this helped.
Marty
Solomon
Quote from: MartyParsons on March 11, 2017, 08:25:01 PM
Hello,
Glad this helped.
Marty
This is a fantastic thread !    I have the 51 hp  Cat/perkins on my mill.   It's a  Logmaster LM4.    It is a 2008 year model.
  I bought it new and it probably has 600 hours on it,  that's a rough guess as I don't have an hour meter on it but I'm a part time sawyer.   It is certainly well under 1000 hours.
Other than being cold natured and hard to start in the cold, I have had no trouble with it at all.
Would you guess this year model to have the old gasket or the updated gasket ?   as they built the mill and called it a 2008  the motor could be an 07 or an 06 (MAYBE),
  Would my local Cat dealer be able to order the crank support kit ?    I think you're right, that sound like cheap insurance when a new motor is 8k.
  I am going to go back and reread this entire thread a couple of more times.
Thank You Marty for sharing this information with all of us and your knowledge as well.
Very worthwhile thread and thanks for thinking of the rest of us.  That's a rare quality in people these days. :P
Time and Money,  If you have the one, you rarely have the other.
The Path to Salvation is narrow, and the path to damnnation is wide.
slider
Solomon,the new style gaskets are 2 piece metal and riveted together.The old style is some type of fiber materal. From the fuel pump side you can see the rivets at the front and rear of the engine.I think the crank support is something woodmizer came up with.I can't see you getting it any cheaper at cat. My old gasket was not metal.
al glenn
Solomon
Thanks Slider,  It's cold as a witch's behind here today.   When it warms up next week (according to that weather man who tells a lot of half truths)
I will go out there ' pull the cover off and have a look.
That crank support , no doupt, would not work on my LM4 as it is a WM part.
I am concerned about the head gasket though now that I've beem made aware of the exisiting problem.  Replacing a head gasket is no big deal, Replacing a motor is an expense I can't really afford.
I'd rather put that money into my Grandson's colledge tuition fund I've been building on for a few years now.
I learn something every time I log onto the FF and this is the only site I know of where 99 and 44/100 % of the folks on here ,
"ARE WHO THEY SAY THEY ARE"
And the phoney's are easy to spot !
  If I look at my Perkapillar and get unsure of what I'm looking for , I will PM a couple of you good folks on here.
Thanks to everybody on this forum.  You all make this the best place on the web to come to and spend a litte time.
I need to take a vacation and travel around some and acually meet some of you good folks in person.
Kbeitz
I would think that I would not to hard to make a crank support
for a engine.
Love machine shop work
and Wood work shop work
And now a saw mill work
Gearbox
Are you guy's with head gasket problems running extended life antifreeze or dipping it with test strips ? I use test strips and add Nalcool from NAPA .
Solomon
Hmm,  food for thought....   I do have access to a machine shop and a good machinist.  bearings are cheap enough as well.   :P
petefrom bearswamp
Bit the bullet and ordered the support kit.
In the 2 years since this thread was started by Marty it has gone up $100.
seems excessive but oh well.
I dont see any rivets on my head gasket but it is metal.
Also going to address my leaking oil pan before i start sawing this yr.
where do I find the tightening sequence for the head bolts?
Only 1100 hrs now after 9 yrs.
I'm getting older and slower.
Kubota 900 RTV
petefrom bearswamp
Ouch no responses yet.
I had hoped for some advice.
Kubota 900 RTV
drobertson
All this great info from a dealer, heard nothing from Indy on this end concerning my cat. Even scoured the net, nothing, so, just saying will corporate chime in?  Seems a bit strange,
4x4American
Why not check with the engine mfg for the torque specs and pattern?  That guy Ben who bought 1x6's or whatever from you he's a diesel mechanic he may be able to help
MartyParsons
Hello
I am out of the office. Google 2.2 Perkins head torque spec. I have a diagram in my desk.
I can get it Sat
M
petefrom bearswamp
Thanks Marty.
The head gasket on my mill is steel, but very thin.
I cut a piece off and it measures .010"
Should I plan to replace this?
Someone posted earlier that the original is some type of fiber, is this the case?
Also my pan gasket is leaking.
It almost looks like I can just take everything off of the fuel pump side and pivot it on the pivot points to get the pan off.
Has anyone done this or will I have to pull the whole shebang.
My mechanical ability ended when I had to start using wrenches other than 1/2 and 9/16 and a flat and phillips screwdriver.
Kubota 900 RTV
irvi00
Unfortunately I have been down the road with "perkapillars". It cost me 25 grand. I will never buy cat or Perkins again.
MartyParsons
Hello,
   Put clean engine Oil on the threads of the bolts. The bolts are tightened in a sequence. ( Picture I have is way beyond copy and paste) Start at the center and work your way out. If you don't understand let me know.
Torque for bolts for 2.2/3024C and 2.2/3024CT - - - ( 74.5 lb ft)
Repeat the procedure to ensure that all of the bolts are tightened to the correct torque.
Intake valve lash clearance .006
Exhaust Valve lash clearance .006
Hope this helps.
Marty
