Woodmizer Carbide Blades?
Started by rmack, November 11, 2013, 08:08:54 PM
rmack
the foundation for a successful life is being able to recognize what to least expect the most... (anonymous)
Welder Bob
2012 LT40HDSD35 Yanmar Diesel Triple
1972 Patrick AR-5
Massey Ferguson GC2410TLB Diesel Triple
Belsaw Boat Anchor
rmack
btw, does anyone know what the first thing is that they are demonstrating in this video?
http://www.youtube.com/watch?v=dcc5thEAwiQ
Welder Bob
1972 Patrick AR-5
Belsaw Boat Anchor
Peter Drouin
I don;t know what the clamp thing is , maybe a thing to hold down a cant if it lifts up so can pull it down
and I have not use the carbide blades .when you get some let us know how they work  :D ;D
A&P saw Mill LLC.
License NH softwood grader.
drobertson
That's what it looks like to me too,  I reckon it beats the boomer all to pieces if so, it just looks limited to  a specific length there,   david
pineywoods
I won one as a door prize at the pg roast. Tried it on pine and oak. Cuts well, smooth cut. Lasts longer than a steel blade.
Downside.. Each tooth cuts a full kerf width, no left tooth, raker, right tooth, therefore requires more power to pull it through the wood. On a low powered mill, it's a bit slower..Requires a cbn sharpener, no way to change the set(it actually has zero set). I keep it for special occasions, like sawing dry hickory or osage...
drobertson
Thanks piney for the post, I have never used a carbide band, although thought about it many times.   Sharpening is the issue with these bands for sure.  I have been through many of logs, dried and hard to soft and doty.  I think that the bands available (excluding carbide) will and should do the job. But if someone wants to run the carbides, then go for it.  My experience with carbide is speed, and more speed, we are regulated by our set up as bought, no way to increase the speeds on the band.  Therefore, run what the machine is designed.  Just a thought, from a way tired soul, ready for bed.  david
