Cross tie logs cost
Started by CaseyK, March 02, 2015, 03:14:59 PM
CaseyK
What is everbody paying for cross tie logs?
Home built automated twin blade
drobertson
Not sure about down south, might redefine your search for your area, or ask or check the mils in your area, as well as what the going rate is for buying timber down there,  around here in southern Missouri, at last check it was straight line run of hardwoods, oaks, and hickory generally speaking, $380/thousand,avg, this will produce mostly 7x9's with the occasional 6x8's and 4x6's, you see it is difficult to but just one size tie log which most would agree being a 12" log.   Getting in on buying logs around here for the flooring and tie market is not so easy anymore without buying loads everyday, maybe twice a day, from maybe two or more logging outfits.  Planning big is about the only way to do it around here, unless one has a logging crew, a mill crew, and a bank account to handle it.  Now if one were to get in, and big, then it will work, pretty sure of that, cash flow is of the essence as is turning out the stock.   Hope you get it figured out for yourself.
rooster 58
I'm paying 300/1000 for mixed hardwoods and 400 for oak
GeneWengert-WoodDoc
Tie logs in the woods are running around $250 to $350 per MBF, Doyle, in WI area, but we can expect large increases in tie prices because the pipeline did not become law, which means either great profits when making ties, or higher log prices.
Southside
Gene -
Do you see an increase in RR construction as a result of the pipeline veto?
White Oak Meadows
schmism
Quote from: Southside logger on March 03, 2015, 11:00:17 AM
In 2010 they shipped about 5.5 mill barrels per day on the RR.    this year they are expecting that number to climb to 9 mill.  (nearly double)
so yes, increased RR traffic would lead to more maintenance and perhaps added track miles.
039 Stihl 010AV  NH TC33D FEL, with toys
JB Griffin
$440/mbf for #1, $415/mbf for #2, 11" and up.
$250/mbf for #3 that are smaller than 11" down to 9"
$350/mbf for 2nd's (gum, ash, elm, hackberry, sycamore, etc.) 11" and up.
Hopefully logs will go down now that grade for flooring fell $300/mbf over the last 3mos. :-\
2000 LT40hyd remote 33hp Kubota with 6gpm hyd unit, 150 Prentice, WM bms250, Suffolk dual tooth setter
Over 3.5million bdft sawn with a Baker Dominator.
Southside
Quote from: JB Griffin on March 03, 2015, 02:09:58 PM
May the hose monster and his buddy the hidden steel gremlin infest your mill for a thousand eternities.....  :D
White Oak Meadows
stavebuyer
$.45-$.50 bf Doyle for tie logs here. Flooring lumber and log prices dropping weekly. Expecting the drop will impact tie logs, pallet cants, and eventually sawn ties. Flooring pretty well drives the market and we aren't hearing anything positive from our flooring customers.
