What size tractor do I need
Started by AndyB, June 24, 2003, 07:44:17 PM
AndyB
I'm new at this sawmill game so need some help.
I have a WM LT15 standard equipment.  I purchased it for personal use.  I turn wood and build craftsman/stickley style antique reproductions.  This is a hobby for me guys,  I don't want to get into the business.  I'm too old for that.  How old? I was the right guide for the three wise men.
With the standard equipment I don't plan to cut logs any larger than 24"x 10-1/2'.  Because my needs aren't that big I have sources for an abundant supply of red/white oak, maple, cherry etc.
I've looked at tractors with 2000 and 2800lb lift capacity at max height.  I'm not a former marine so don't want to hunt squirrel with a 105MM Howitzer.
Any input would be greatly appreciated.
kip
I have a 25hp Yanmar (gray market) tractor with a boom pole that I use and it works great. I do wish I had a FEL for it though. I wouldn't go any smaller than a 20hp if I were you.
Kip
Tex-saw
I would suggest a least a 35hp tractor,a 10' 24" oak log could easy weigh 1500 if you are going to use the rear 3pt to lift and skid the logs you can get by with a smaller tractor but if you plan on using a front end loader youll need a biger one I got a 72hp case ih with loader and it can handel anything i throw a it, the rear tires were filled with soild rubber and weigh 1800 a pice so with that kind of counter weigh and 3000 pounds fo lift it gets the job done when i start picken up big stacks of lumber i would'nt want none smaller 8) 8)
Neil_B
AndyB,
As long as you can still get out of bed in the morning, your never TOO old. ;)
My father in law has an older Massey 165 with loader. Not sure the HP but it will pick up most logs he comes across. However it would not pick up a 20" x 10' green oak log. It's a good strong tractor but not strong enough for the big un's.
I've got a Massey 50H backhoe that I picked up for $17000, it's a '92. Around 80+ HP I think, but it will pick up over 4500#s. Probably more if I cleaned up the hydraulics and filled the tires. Also made up a set of forks for it as well for lumber stacks.
Handy as all get out for reworking the landscape ;D.
Timberwolf / TimberPro sawmill, Woodmizer edger, both with Kubota diesels. '92 Massey Ferguson 50H backhoe, '92 Ford F450 with 14' dump/ flatbed and of course an '88 GMC 3500 pickup.
Norm
For what you want to lift a 50hp tractor with a FEL would work pretty well. We used to have a JD5300 that would lift about 3000 with a good counter weight on back. I wouldn't go much less than 40hp. One nice thing about utility tractors is they hold their value so well. We had a 40hp deutz in pretty rough shape that we sold through the farm spokesman and got a ton of calls for it. Good luck, after you get one you'll never realize how you lived without one before.
woodmills1
I must say that I agree that if you want to lift with the loader or a set of forks then there is no substitute for horsepower.
However, that said take a look at the various tracktor based forwarding trailers that have been appearing lately. Patu and metavic are the two names I remember but there are many more.  get a copy of sawmill and woodlot magazine and look for stories or ads.    http://www.sawmillmag.com/
I have a 30.5 horse Kioti lk3054 with a metavic forwarding trailer and this combo has really turned me into a one man show.  I regularly fell and load medium sized red oaks.  the loader will handle 16' red oak butt logs around 14" at the top.  larger than that I will spin one end at a time onto my woodmizer.  There have been only a few huge butts that came off of loads that I purchased that the loader wouldnt lift.  two real large ones, over 30" I ripped with my chainsaw, but others I skidded over to the saw with the tractor and then pushed and rolled with the bucket.
the trailer also makes a great slab or lumber holder while cutting.  I was lucky enough to find the package for $16,000 used, though I added an FEL later for more $$.
Bibbyman
One suggestion I would add.  Take note of the front axle and tire combination to make sure it can handle the weight and be able to move.  A front-end loader is an adaptation to most farm tractors and the front axles and tires on standard 2wd models are on the light side for front end loader use.
I ran a 3444 IH industrial tractor (backhoe with out the backhoe - if that makes sense).  It had great hydraulics and could lift anything you could stick the forks under.  Had a big heavy front axle and spindles and wide industrial tires.  I could align logs or bunch them just by running the front tire up against them and turning the wheel - it had that much power and strength in the front axle and steering. Problem was,  even with loaded back tires and chains,  you couldn't move on soft ground with a load.  I'm not talking soft and in muddy.  I'm talking soft as in anywhere but a packed roadbed.
We ran and are still using an Agco Allis 4660 w FWA.  FWA (four wheel drive) solved the problem of heavy enough axle and big enough tires and traction.  But the overall hydraulics and loader was pretty light and slow compared to the IH industrial tractor.
Although I'm not a fan of Bobcats, used ones are coming available at what looks to be great prices.  Bobcats are becoming quite a versatile platform to mount all kinds of tools like posthole diggers, blades, sweepers, backhoes, trenchers, tree sheers, etc.
Looks like more than one suggestion so I'll add one more...  When shopping for a tractor that you intend to use with a front loader,  check out the hydraulic pump specs.  The more GPM the faster it will lift and work.  Most farm tractors have really slow pumps compared to an industrial type of machine.
Sawing since '94
Percy
Ill give a plug for the skid steers(bobcats). They are just the handiest things.They dont skid logs werth a poop and do chew up the yard if you dont learn how to turn properly. On the positive, if it cant lift it, it will roll it/whatever. My son moved a 40 foot WRC,36 inch at the butt(one end at a time)accross the yard(he's a good operator) without too much trouble.
D._Frederick
I will second what Bibby said about 2WD tractor front axle being weak. I have a Case/IH that has a welded together front axle that has cracked/split from the stress of the front loader. On the plus side, the turning radius is smaller with this axle. Some makes of tractors can be bought with cast iron front axles that will stand the stress of a loader. The small 20-30hp tractors with front wheel drive also have problems with front axle, when they are used in all wheel drive. The drive system will not stand-up when the weight is transfered to the front, it tears the gearing out.
Bibbyman
Another thing to consider when using any loader to move logs is their length and center of gravity.  You may be lifting a 2000 lb log and as far as total weight be ok.  But it's real easy to get the center of gravity off by a foot or more and the majority of the load is on one side.  When lifting logs from a pile or off a truck,  it's real easy to get more than one (two or three) to roll off onto the forks at one time - sometimes very off center.  Makes for some tense moments and real tough on the machine.
Another tip,  keep the load low and go slow.  I have a couple of young farmer neighbors who keep breaking axles and spindles out of their JD 2wd tractors.  I suspect it's because they stick a big round bale and take off down the road with it at a speed that would be fast enough without a load.  The bounce of the bale multiples the load stress many times over.  They have replaced the broken axles with axle assemblies from larger models.
Sawing since '94
shopteacher
I bought a Massey 4WD 1240E with FEL and backhoe about 5 years ago.  It will pick up some pretty large logs but the problem I had was shearing off the 6 grade 5 bolts that held the FEL to the frame.  I have about $25,000. in that machine and it doesn't make sense to tear it up doing things it wasn't meant to do.  I kept an eye on the machinery trader internet site and found a real nice JD 8875 skid steer in Hamilton, Canada. Drove up, run it around the lot a bit and made the deal to have it delivered close to Pittsburgh. The dealer took care of the transportation and paperwork across the border.  It's a great machine. I've been using it to lift pallets of shingles( 32 bundles to a pallet @ 70 lb each) and it lifts them full stroke without hesitation.  The kids at school needed a welding project and I drew up a bucket to sift out large rocks, concrete and cement block from fill. It works great.  I have post hole drill for a 3 pt. hitch I plan to adapt next.  My best advice is to take your time, research(as your now doing) and find the right machine for your application. You won't be sorry.
The picture has the school made bucket on it.
 Anybody want to swing by G.R., like tomorrow? I got a couple of big 'uns on my trailer and can't get them off without smashing them up.
 Anybody have any clue what a used Hughs Loader with gas engine, bucket, log forks, and 4000 hours on it might go for? I just found one that is in really good (relitive to loaders) shape and the owner is just taking offers.
Larry
I'm not to hot on skid steers because they tear up so much ground especially if your not careful or the ground is wet.  At the same time the prices are really attractive for used good machines.  A lot of 1845 & 1845C Case skid steers in very good condition are selling at decent prices and they will do a lot of work.
Neighbor got a late model bigger used Bobcat.  Looked almost new and not a lot of hours. Asked him where he got it.  He got it from the local rental place.  Apparently they turn them around after a year or two because they are so popular.
Not for sure on this but I think Bobcat came out with quick attach system for the FEL, which is, pretty much industry standard now.  If I am wrong somebody will correct me but that would be something to check out.
Yeah, we have a big auction every spring and fall. All the local rental Co. as well as any other heavy equipment owners come. Prices can differ but most rental bobcats have had some mis-use.
 It is fun to go play with all the toys though, where else can I j go just to use a 60' sky jack without a waiver?  ;) :D :D :D
shopteacher
Furby,
   You better be careful with that sky jack talk. You'll have the feds at your front door.  :D :D :D
 :D :D :D :D :D :D :D :D :D :D :D :D :D :D
O.K., O.K., O.K. I missed that one! Good job!
Kevin
Having an LT 15 I would ask why do you need a tractor?
Unless the logs are coming from your own property and must be skid to the mill.
If this supply is to be delivered then have it dropped at a staging area beside the mill.
Problem solved!
The Problem Solver  ;D
I have a Ford 1910 4wd with Front End Loader. It is rated at 28 Horse drawbar and estimated at 35 horse at the wheels because of the 4wd.   It has done a yoemans job of skidding logs from my place to the mill.  The FEL can position logs that it can't lift.
The biggest concern I have with a FEL is that there is no protection.  Think about it.  If you lift a log too high and it gets away from you over the back of the bucket, there is nothing between the tractor operator and the log but a quick "aw sh**".
Be sure, whatever tractor you use, that you weld a bar in front of the operator or a framework on the FEL to stop a log from killing someone.  This is a well known danger in the hay industry where tractor operators can end up with a round bale in their lap real quick.
Larry
Tom, I never could resist a deal so I bought 1,200 tons of ballast or gravel off a Burlington Northern railroad spur they were going to wreck out.  Figured out real quick that I didn't have any way to get all that gravel home so ran out and bought a FEL for my little Ford 1720.  Roped in the neighbor with his little 6-ton dumptruck to help for a share of the gravel.  Very first thing I did when loading the dumptruck was to rotate the bucket to far back and shower gravel all over the front of the tractor.  There was also a piece of railroad iron in that bucket which put a big crease in the tin of my almost new tractor.  Every time I use the loader I see that big crease on the tractor and THINK.  Sure would hate to think of what a log would have done if it rolled backwards off of the forks I use now.
Guess I was lucky.
Paid heed to Tom's advice.
Welcome to the Forestry Forum, Tex-Saw.
Just what we need.......more Texans.   Sigh!
Don Staples must be recruiting. :D
shopteacher
You usually only get one chance at safety.  It takes me 5 weeks to go over all the equipment and safety orientation at the beginning of each wood I class.  We've been very fortunate in only having a few minor cuts, scratches and bumps.  Expect the unexpected.  Take Tom's advice.
bull
I WILL START BY SAYING *( KUBOTA)******
I STARTED SAWING W/ AN LT 15 IN 98 ALSO HAD AN
87 L2550 KUBOTA 29 HP 4X4 W/ FRONTEND LOADER AND STUB FORKS MADE FROM BOX CHANNEL.... WORK VERY WELL  ALL AROUND THE MILL WAS GREAT IN THE WOOD LOT AND USED IT FOR ALL MY SKIDDING 100 ACRES MIXED HARD-SOFT WOOD... ALSO USED IT IN MY LANDSCAPE BUISNESS AND ON THE FARM GREAT LITTLE MACHINE BOUGHT IT NEW IN 1987 SOLD IT TO A FRIEND IN 2000 STILL RUNNING STRONG TODAY i UPDATED TO A 2000 4610 HST 50 HP 4X4 W/ QUICK ATTACH BUCKET AND FORKS.  I HAVE HAD OTHER PEOPLE TELL ME THEY WERE BUYING A KUBOTA AFTER SEEING THEN WORK I HAVE DONE W/ MINE SOME THINGE A QUITE UNBELIEVEABLE ...
THE 2550 COULD SKID 5 16' OAK LOGS W/ 16 INCH TIPS.... AND I ALSO HAVE MOVED 16' OAK LOG WITH 24" TIP AND LOADED IT ONTO THE LT 15 WHAT A WORK OUT
PEFECT BALANCE WAS THE SECRET.... THE 4610 HAS A ONE YARD BUCKET AND WE USE IT TO LOAD BARK MULCH DAILY. THE LARGEST LOG FOR THE 4610 WAS A WHITE PINE 20' W/ A 34" TIP...  18' OAK W 24" TIP ......
GO KUBOTA..... 8)
hawby
Bull,
Lotsa shouting about Orange brand there  :D I had a Green 770 for 5 yrs that did everything I ever asked of it. Do to an unfortunate event (Starts with D, has been sung about) I had to sell it. In less than 18 hours, sold it for $2,000 more than I paid for it 8) I miss that thing :'( :'(
So, yesterday, with a different budget mindset and different needs, I bought a Bobkitty. Not a skidsteer, but an articulated loader. Now, I have not had an opportunity to talk much with it, but I can't wait to hear how "articulate" it is  :P
Seriously, I am very interested in how well it will handle logs. It has a 1600# lift, 3200# tip spec. The articulation is supposed to help keep from tearing up the ground. I did a full tight circle in the owner's yard and never left a divet. (Can you say, "new lawnmower?"
I got two buckets, and a set of forks. I'll take pics when I get it home....soon, I hope.
As for the safety factor, I will be welding a clamp on to the forks that will be able to be taken off/on as needed. (Until I can afford the grapple bucket.)
Lastly, Orange, Blue, Green, Red, White after 40 years of farming and farm related activities... I feel that it is how you treat them, maintain them, and fit the use to the design that determines whether you have a success or failure, more so than brand. I have attended two funerals where someone tried to do more with a tractor than it was designed to do.
No one is more brand loyal than me... but guess what after almost 4 decades of loving Bowties, I have finally had to admit that they now have a really sucky design department and I am gonna have to swallow my pride and buy one of those so called Better Idea trucks.
hawby
Hawby
Missin' loggin', but luvin' the steady check...
Tex-saw
Thanks Tom, real nice forum lots of info, you can never have to many Texans! 8)
bull
HAWBY...
  HERE'S MY TRACTOR HISTORY
 FORD 8N, 2000 INDUSTRIALW/LOADER,DEXTER,
 SUPER DEXTER  W/ 1 ARM BANDIT
 FARMALL CUB, A,SUPER C,H,M
 JOHNDEERE A,B,3020,3010,2010,820
 2030W/LOADER,2510,2240W/LOADER,2940,4020
 KUBOTA  195 4X4  L 2550 4X4 W/LOADER L4610 4X4
 W/LOADER
 YOU ARE RIGHT ABOUT THE TRACTOR FITING ITS APPLICATION.
 I JUST FEEL THAT THE KUBOTA FITS IN BEST ALL AROUND THE FARM AND MILL...... I GUESS ITS JUST PERSONAL PREFERENCE.....
 I STILL HAVE THE 8N AND THE CUB THEY WERE MY GRANDFATHERS AND HE GAVE THEM TO ME WHEN I STARTED FARMING....... I WILL PASS THEM ON IN MY LATER DAYS....... THE OTHERS ALL WENT AS THEY BECAME OBSELETE ---- GOT OUT OF DAIRY FARMING--
GOT OUT OF HAYING AND RENTED OUT THE FIELDS,, HEADED FOR THE WOODLOT AND NOW IM HANGING OUT AT THE SAWMILL...... I'LL SEE HOW LONG THAT LASTS.....MAY GET BACK INTO HAYING.... WINTER HAY IS BRINGING $4.00 A BALE OR BETTER AROUND HERE
AND CONSTRUCTION HAY WILL BRING $2.50 OR BETTER YEAR ROUND. ;) THE 2000 4610 KUBOTA WILL BE AROUND FOR A WHILE AND I WILL ADD ANOTHER KUBOTA W/ CAB ETC 80 HP OR BIGGER NEXT YEAR
