Darra James table saw
Started by yukon cornelius, April 17, 2016, 08:37:12 AM
yukon cornelius
I was auctioning yesterday and came home with a big darra James cabinet saw, a 12 inch craftsman band saw and a radial arm saw. It is in nice shape but needs a bit of fence work. I have my plan to get it back in line. I have been unable to locate a model number. It came with a 10" blade but looks like a 12 will easily fit. I read of a 3\4" arbor on them. Does anyone know of a 1" to 3\4" arbor bushing for a 12" blade? Can a 10 inch blade be safely drilled from5/8 to 3\4"?
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
I tried kinda unsuccessfully drilling out a 5½" blade.  :-\
My thoughts are that you might be more successful reaming out the hole rather than drilling.
yukon cornelius
Not a bad idea! That may be more successful
Kbeitz
Love machine shop work
and Wood work shop work
And now a saw mill work
yukon cornelius
I never even considered having them drill one. I can get stuck on box store availability some times.
dnalley
You won't get a round hole with a drill bit.  Better have it bored.
Dan_Shade
Would a step drill or unibit work?
lots of dull bands and chains
dnalley
Don't know what a uni bit is but a drill just doesn't make a truly round hole.  Looks good till you really give it a close look.  Sometimes looks sorta triangular shaped if you really look it over.  I would hope for a closer tolerance for a blade running on an arbor.  Just my opinion.
Savannahdan
Husqvarna 3120XP, Makita DCS7901 Chainsaw, 30" & 56" Granberg Chain Saw Mill, Logosol M8 Farmers Mill
yukon cornelius
Yesterday I reamed out a 10" blade and put it to work. I ended up swapping wings from one side to the other for a wider cut. With a bit of reworking on the fence this will be a huge upgrade. The far end of the fence was missing some parts and had some homebrew repair that I don't care for so I am redoing it. Next I want to add more to the table to have at least 48 inches of cutting surface.
ozarkgem
Blades are pretty hard metal. Boring with a carbide cutter would work. I don't think a unibit will hold up. Glad you scored big at the auction.
hackberry jake
I also have a 12" table saw with a 3/4" arbor. I usually use 10" blades that have been cut from 5/8" hole to 3/4". The best way is to use a milling machine with a rotary table. Perfectly round and perfectly centered. Send yours to me and I'll mill em and send em back. You could also use shaper bushings to bush a 1" blade down to 3/4".There might even be something that'll work in that molding head set I sent you.
Never mind. There's nothing that goes up to 1" in those sets.
