is there any kind of a market for pith elm that has a 48" butt
Started by air1514, December 07, 2011, 09:14:02 PM
air1514
i cut a pith elm that has a 48" butt log and another 40" log and then 3 smaller logs. not sure of the feet they would saw out but it should be more than 1000bf.   the owner of the tree says that it would make a beautyful table or something and hes convinced its worth alot.  the sawmill in my area that i take all my sawlogs to said pith elm wasnt worth sawing and he culled the 40" in and the smaller logs. i will go back and get those culled logs if i can sell them.  all the logs are solid and clear. my question is--   are the logs worth anything at all. and do they make pretty lumber if they were sawed by a private mill. ill post a pic if i can figure out how.
I think that elm has a beautiful grain.  The wavy bands of latewood pores create a unique effect that only elm has.  It is hard to dry because elm has spiral grain, and the lumber is prone to twist and warp, one reason that it is not a popular sawlog.
Think about sawing slabs, some 2" and some 3" thick and as wide as possible.  Then, if there is some warp, there is enough thickness to flatten the dried slabs.  I think that elm, once dry and stable, would make a really nice table.
air1514
this is the stump
PHOTOS MUST BE IN YOUR FORESTRY FORUM GALLERY IN JPG FORMAT. USING THE DOCUMENT ATTACHMENT MANAGER FOR PHOTOS IS NOT ALLOWED
[attachment deleted by admin]
LeeB
Al_Smith
Elm makes the most excellant planks for loading equipment .The stuff will bend like rubber before it breaks and is nearly split proof .Oak will just plain break once it's over loaded ,never gets any lighter  and splits out the ends when it does dry out .
air1514
here are a couple more pics of the butt log
SPIKER
AIR:
the pics should be in JPG format for most people to be able to view them.  the windows pic viewer didnt work correctly for mine.
mark
Ironwood
"worth alot", well perhaps after milled dried and marketed. See walnut Youtube thread ;D
I could be neat, but he gotta get find someone who wants it,....in the 4000+ lbs log form :D. I would give a little for it if it were just down the street. The whole opportunity cost equation comes to mind, close, cheap, worth a "try". If it were delivered to me, maybe $150. If i gotta bring truck, w/ crane, $25-75, if it were down the street. Is that alot? to me it is alot, I sit on alot of wood that doesnt have ready markets. So it has little value.
Ironwood
