Husky 51
Started by naturaledge1, April 09, 2019, 05:30:29 PM
naturaledge1
I have two husky 51s that I bought used and they both eat up the pulley inside on the recoil. The dawgs don't seem to engage enough anybody else have this problem?
Old Greenhorn
Welcome to the forum! Is everything good and clean in there? if the dogs don't slide easy and there is junk in there they can't fully engage. Without more or some photos, I can't add more. Some others, I expect, will chime in here eventually with better advice.
 By the way, filling in some of your profile info will help us all know where you are, what sorts of gear you run, etc. which might get you some better help. Maybe we even have a member close to you.
dougand3
So, you have seen the pulleys get more chewed up since you got the saws? Never seen it but what is logical....weak springs under dawgs. Springs should hold dawgs firmly on pulley until RPMs kick up. Finger pop the dawgs - do they snap back quickly and firmly? Could be springs are strong enough but the long end is on the wrong flywheel fin.
