Video when I saw birch
Started by teed, April 18, 2015, 09:17:35 PM
teed
Today i haw saw birch planks with my Logosol Farmers M8 chanesaw mill
http://www.youtube.com/watch?v=TMqLPDVlzuo&fmt=22
On my homestead, I mill with.
Logosol B1001 bandsaw mill
Woodland mill HM122 bandsaw mill
Logosol F2 with Speedsaw E5 chainsaw mill
Logosol Farmers with Stihl MS391 and MS661
Percy
That thing works pretty slick smiley_biggrin01 smiley_biggrin01 smiley_biggrin01
Works good, but a slow way to make a living.  ;D
Chuck White
Nice video, thanks for posting.
teed
Quote from: SwampDonkey on April 19, 2015, 05:54:24 AM
haha you will never win any speed competition, but it works great for home consumption.
Another way to skin dat cat.   ;D
Nomad
     Nice job Teed, and good looking boards too!  Do you need to use wedges on the longer or wider cuts?
WoodMizer LT50HDD51-WR
Lucas DSM23-19
teed
Quote from: nomad on April 19, 2015, 07:28:23 PM
Hey!
It works well without wedge. And usually I tend not to use it, if it's not too much stress into the board.
Then it can help a lot.
Nice. What's the planks going to be used for?
teed
Quote from: thecfarm on April 20, 2015, 08:25:52 AM
I really do not know what they should be for. But I love to build furniture, so it's always nice with a stock of wood to choose from when starting a new project.
That set up any good for a 30" (not but diameter) yellow birch? I could get boards out of the bush easier than a several 100 lb log. ;D
teed
Quote from: SwampDonkey on April 20, 2015, 04:55:51 PM
do not think you can cut 30 "but is good enough to run logs that are 23-25" and weighs 1100lbs
Billbob
Nice work Teed!  Good looking lumber and those slabs will make great firewood.
Woodland Hm126 sawmill, LS 72hp tractor with FEL, homemade log winch, 8ft pulp trailer, Husqvarna 50, Husqvarna 353, homemade wood splitter, 12ft dump trailer, Polaris Sportsman 500 with ATV dump trailer
teed
Quote from: Billbob on April 21, 2015, 12:02:42 PM
I am in the the process of learning me to say. So I try to cut as much as I can to see if it is good or bad. When you live as far north as I am it is good that some become firewood, otherwise it will be cold in the winter  :D
drobertson
Heck of a deal there, I think this is the second one I've seen running, pretty impressive,  no need to let timbers go to waste,
Billbob
Quote from: teed on April 22, 2015, 08:42:32 AM
You know it's been a bad winter when March arrives and you have to start busting up furniture to use as firewood!  :D
I've seen in the past a woodshed or two make the fire brigade.  Of course after the wood piles were exhausted inside. ;D
21incher
Nice video, thanks for sharing. Looks like you get a pretty good workout with that mill. :)
teed
Quote from: 21incher on May 02, 2015, 07:04:09 PM
8) Yep need time to build a saw table, so I can lift the logs in the correct height and avoid lifting them
Probably want to elevate the logs about waist high don't you?  Don't go too high or that will be a workout to, especially 20"+ logs. ;D
justallan1
Very cool. That's getting the job done.
