230 hydraulic pump?
Started by Maine logger88, October 18, 2014, 07:08:22 PM
Maine logger88
A guy I know has a new hydraulic pump for a 66 or 67 i think 230 (it has the chin tank) my question is will it fit my 79 225. He doesn't want much for it so if its the same I will buy it for a spare
redneck
If it is a cesna pump it likely will.
Mine leaked around the shaft seal when it was worn out.  repalced seal a few times but finally bought a new one at harrolds logging  for 600 bucks
208 timberjack 353 detroit, case 580 super K backhoe, homemade bandmill, 357xp, 372xpg
Maine logger88
Yes it is a cesna. He is only asking 100$ he sold the machine years ago and has no use for the pump. It is worth that for sure
jocco
Some of those were hard to rebuild  ;D Next why is it spare and not on a machine??? :) They are $600 for a reason.
You may check out but you will never leave
Maine logger88
His had trouble so he thought it was the pump so he bought this one new it didn't fix the problem. It turned out it was a problem with something in the suction in the tank I can't remember exactly what he said. So he took the pump off and put his old one on cause his old one was fine
