Chamfer Chisel
Started by Ohio_Bill, February 24, 2005, 07:33:48 PM
Ohio_Bill
Is anyone useing the Chamfer Chisel chain  ?  I was reading about it and it says  the cutters have an angular shape with twin cutting corners , which allows good performance and easy maintenance .  The chain I was reading about is Oregon,s 91VS.  I was thinking about useing this chain on a Stihl o26 .
thanks
Bill
Bill
USAF Veteran  C141 Loadmaster
LT 40 HDD42-RA   , Allis Chalmers I 500 Forklift , Allis Chalmers 840 Loader , International 4300 , Zetor 6245 Tractor – Loader ,Bob Cat 763 , Riehl Steel Edger
jokers
Quote from: Ohio_Bill on February 24, 2005, 07:33:48 PM......The chain I was reading about is Oregon,s 91VS.  I was thinking about useing this chain on a Stihl o26 .
thanks
Bill
AHHHHH......... DON`t DO IT! 91vs is made for smaller saws that don`t have the power to run anything bigger.
The 91vs which is 3/8 Lo Pro is actually much smaller than a typical .325 chain. Try just about anything else in .325 or standard 3/8 on your 026 and it will easily outcut the 91vs.
Russ
devo
I converted my 026 to use .375 (easy to do) and have never looked back. Don't use the LoPro chain, it's no good on anything that is capable of turning a bigger chain.
Crazy enough to try it! (once)
Ohio_Bill
Thanks Guys , I won't try that chain .  When I got the saw it had 325 and I currentley have 375 on it  .  sounds like I should stay there.
thanks
Bill
Bill
